speedbump Posted February 27, 2004 Share Posted February 27, 2004 Could I use the knock sensor from the 90 ea82t with the harness and ecm in my 86 ?The old failed one has 2 wires and the new one has one.If anyone has a good engine diagram,or knows the answer,please help.Parts like this are stuipd expensive up here. Or can I run with it disconnected,or jumped out so it sends no errant signal back? thanks Quote Link to comment Share on other sites More sharing options...
Meeky Moose Posted February 27, 2004 Share Posted February 27, 2004 well.. nope... going through the same thing myself.. the nwer style 87-94 ea82T knock sensors are different than the 85-86.. along with the distributor, maf, and ecu.. won't work.. sorry.. new 85-86' knock sensors here are $250 from the dealer and $125 from advance.. i got lucky and got one from a board member.. Quote Link to comment Share on other sites More sharing options...
rallyruss Posted February 27, 2004 Share Posted February 27, 2004 I will look later I may have one in my misc stuff. and yeah you can just ground the signal wire and it should eliminate the knock sensor input to the ecm. temporarily that is. its a safety device. Quote Link to comment Share on other sites More sharing options...
speedbump Posted February 27, 2004 Author Share Posted February 27, 2004 ha ha! We mistakenly set the timing to13 deg btdc,instead of 25.I set it properly and now super roo roars!Gotta be careful now though,I cant keep from spinnng the tires off a green light! Thanks all for helping a guy who was too dumb to check the simple things first.It turns out the repair on the knock sensor worked any way,Iwould have had a chek engine light if it didnt,apparently! Quote Link to comment Share on other sites More sharing options...
