DOHC EJ25 and SOHC EJ25 crank sprockets the same?
5 replies to this topic
#1 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,010 posts
  • East Coast
Posted 25 April 2011 - 10:52 AM
Are DOHC EJ25 and Phase II SOHC EJ25 crank sprockets the same?
I counted the reluctors (tabs) and it seems like they're the same.
I had two engines apart and could have accidentally mixed up which one is which.
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 25 April 2011 - 10:55 AM
I would think that if your engine has the plastic pulleys, that the metal ones will be backward compatible. But this i assume since subarus seem to be cooperative in that manner.
I am going to be asking a lot of questions about an ej222 in this regard, with what can be retrofitted from an ej22e
#3 idosubaru
idosubaru
  • 24,010 posts
  • East Coast
Posted 25 April 2011 - 11:05 AM
if you specify year, type (phase I or phase II) i can help.
basically you can use any NA EJ block in any EJ vehicle. from there you decide what to bolt on to it based on what you're trying to do.
#4 94Loyale
94Loyale
    I Love EJ22's
  • 461 posts
  • Orwigsburg,Pennsylvania
Posted 26 April 2011 - 12:13 AM
Gary, if the pickup teeth are the same count, and are in the same positions you are fine. They are the same unit.
#5 idosubaru
idosubaru
  • 24,010 posts
  • East Coast
Posted 26 April 2011 - 05:39 AM
great thanks, they were identical as far as number and counting teeth between them.
#6 Fuzpile
Fuzpile
    Banned
  • Banned
  • 318 posts
Posted 26 April 2011 - 11:16 PM
You did your searches and I'm still going to be an ......le I couldn't conceive that different materials present and wear differently at rpms at different temperatures. Not to be concerned with over many miles yet there are differences which the belt has to adjust to. Over and over so ideally they would all be same composition and similar wear. no friends, whatever.:banana:
