front wheels camber
3 replies to this topic
#1 quebechatch
    USMB Regular
  • PipPipPip
  • 50 posts
  • quebec/ Canada
Posted 21 March 2004 - 07:14 PM
Hi Guys!
Can somebody help me? I've just lifted my hatch by 4" and used 5" strut spacer to give it a little more clearance, but here's the trouble: I'm not able to get the camber straith even after making a little more room by hammering the inner fender. what should I do?
#2 calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 22 March 2004 - 01:17 AM
Did you use equivalent lift blocks on the motor and tranny crossmembers? Camber shouldn't be a problem if you lift the body at all contact points.. otherwise, you end up with the problems you have described.. if the body is lfted correctly, the suspension geometry will not change.
#3 soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 22 March 2004 - 08:58 AM
It's a little on the "Fabricators" end of things (but if U made your oun lift:brow: )
I would make longer lower controll arms, use a hime joints for the inner mount. Then U can adjust the camber. Just keep an eye on the inner DOJ so as not to pull it apart when @ full droop and turning;)
If U want to get real hard core with it U could go to EA82 front shafts (they are longer, but the same joints) and build the lowwers to the right length for them;)
#4 ru4x4ever
    Eat, Live, Breath Subaru
  • 349 posts
  • Medford, Oregon
Posted 22 March 2004 - 12:17 PM
I have the same problem!! With my new tires (Will have pics posted tonight) I dont want to wear them down do to poor chamber. But we did all correct. It is gross i want better chamber also!!!:banghead:
