turboing N/A ej22 question
5 replies to this topic
#1 soobie_newbie67
soobie_newbie67
    Eat, Live, Breath Subaru
  • 471 posts
  • Kennewick
Posted 11 October 2012 - 11:29 AM
I believe GD told me the ej22 is capable of taking 10 psi on stock internals, or was that a dream? There's a legacy (gen before mine) and I was wondering if it would be possible to grab the y pipe turbo and downpipe and swap them directly into my engine. And what would I have to go through to run the oil supply line and return line.
#2 mellow65
mellow65
    Subaru, my drug of choice
  • 1,086 posts
  • Portland
Posted 11 October 2012 - 12:03 PM
not sure about what the guts can handle, but i can tell you the flaws in your swapping stuff.
yes the y pipe will bolt up to the engine, but the cross member is different, the turbo cross member is notched for the pipe. the oil feed line is ran from a banjo bolt on the back of the passenger side head, not there on a NA motor. same goes with the oil return line, not there in a NA motor.
sure all those things could be over come, but it probably would end up being cheaper and easier to just find a turbo car and have fun with that, or a turbo motor.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 11 October 2012 - 12:52 PM
5 psi is max on an N/A unless it's tuned for E85.
As noted - oil plumbing and exhaust fitment are just some of the issues you will run into - engine management, intake plumbing, and many other details which are not well documented in the communities are all hurdles to making it run correctly. It's not a simple task.
#4 mellow65
mellow65
  • 1,086 posts
  • Portland
Posted 11 October 2012 - 01:19 PM
have you ever seen a low boost NA motor? I'm wondering how it runs, I keep thinking a low boost turbo, normal compression set up on the mazdaru would be awesome. :clap:
#5 soobie_newbie67
soobie_newbie67
  • 471 posts
  • Kennewick
Posted 11 October 2012 - 02:02 PM
Alright. I think I'm gonna pitch the idea for now then and just wait till I order the legacy gt-b engine cause I will have to change the cross member for that too. No since in removing the engine twice.
#6 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 11 October 2012 - 03:00 PM
A "low boost NA" is technically refered to as a "high compression turbo". Yes I've seen quite a few of these - it's a popular build for race fuel or E85. Especially in the sand rail community.
