SubaRube Posted April 16, 2004 Share Posted April 16, 2004 Does anyone know what the center bore for the E82 hub is? I can't find the info anywhere. All I could find was 60mm for a Justy and 56mm on newer models. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted April 16, 2004 Share Posted April 16, 2004 Do you know if an EA82 is the same as an EA81? I had some custom EA81 rims made and I have those specks. Let me know if you want them or think they are compatible. What are you trying to do to? Glenn 82 SubaruHummer, 01 Forester, Quote Link to comment Share on other sites More sharing options...
SubaRube Posted April 16, 2004 Author Share Posted April 16, 2004 So what is it? It should be close if not the same. It's the only stat I can't locate. Thanks. Quote Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted April 16, 2004 Share Posted April 16, 2004 so what is it? rim or hub? I'm not sure I understand, your thread states rim and the message says hub.I measured a stock H-alloy and a steelie across the center. 95mm, does that sound right? Quote Link to comment Share on other sites More sharing options...
