Need Help 95 Legacy low idle and vibration at 45+ mph...
3 replies to this topic
#1 duffymaddox
duffymaddox
    Member
  • PipPip
  • 19 posts
  • Pittsburgh, PA
Posted 14 June 2013 - 08:30 AM
Hello, I got a 95 legacy from my sister last year Since then I have replaced MAF sensor. and just yesterday had to replace the harmonic balancer (Crankshaft Pully) got loose and reamed out the inside of itself . I know that i have a hole in my exhaust . could that be the cause of my idle issues or should i also look elsewhere. and why does my car vibrate at 45+ mph
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
  • Charlottesburg, VA
Posted 14 June 2013 - 09:05 AM
Most of the time a vibration at speed is because the tires are out of balance.
Low idle can be due to several reasons. Usually it's a vacuum leak. Check the small vacuum hoses that run around on the intake manifold for cracks and splits.
#3 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 14 June 2013 - 09:44 AM
dose crank pully wobble at all ? how bad was front of crank ? and is the timing belt on right ?
#4 duffymaddox
duffymaddox
    Member
  • PipPip
  • 19 posts
  • Pittsburgh, PA
Posted 14 June 2013 - 10:04 AM
The old crank pully was wobbled but i replaced it with a new one it fine i could not get the crank sprocket off to change out the woodruff key ( cause i dont have a puller and did not want to damage anything so i used the old key the pulley went on nice and tight. i made sure that i put the timing belt on withe all the sprokets at center but the left side cam sprocket drifted about a 1/4 in off center but there was a lot of play on that side so I did not think that would matter. I also know that the spring inside the pcv valve does not seem to engage all the way.
Edited by duffymaddox, 14 June 2013 - 10:08 AM.
