Forester rear disc brake conversion
2 replies to this topic
#1 pearlm30
pearlm30
    Eat, Live, Breath Subaru
  • 356 posts
  • Tampa, FL/ Bethlehem, PA
Posted 11 September 2013 - 07:00 PM
MY 98 auto forester with drum brakes needed rear wheel bearings. The donor car is MY 99 with rear disc brakes.
I know I def need e brake cable, but the donor is so rusty I am not sure i can pull everything I need off the donor.
Do the rear brake calibers, hubs and rotors are the same from legacy/outback fit forester?
And any other suggestion?
Thanks a lot!
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 11 September 2013 - 08:43 PM
You can swap the backing plate, but you will have to get the hub out of the bearing to get anything apart.
Edited by MilesFox, 11 September 2013 - 08:43 PM.
#3 bratman18
bratman18
    ADIDASubarus
  • 3,866 posts
  • Jefferson, Maine
Posted 12 September 2013 - 12:27 PM
You just swap the entire rear knuckles with brakes and ebrake cable and abs cable attached.
