ronnieb Posted April 14, 2014 Share Posted April 14, 2014 I am inquiring about suggestions for lifting a 2012 subaru outback. I live near the beach and clearance is important, as the car sits its is going to get bogged down due to trucks making the ruts and softening the sand. I am not intending to kill the car on the beach, just access good surf breaks. My thoughts are: what's the best bang for the buck on lifting and then going to largest most balloonest tires that can fit on a slightly bigger rim. Not looking to make a monster subaru, just enought to sneak by. All positive and negative suggestions are welcome.. Thanks... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 14, 2014 Share Posted April 14, 2014 there are off the shelf 2" lifts for 2000-2004 and maybe 2005-2009 generations. the fronts will be identical to yours. the rear I'm unsure about, have you done a search? Quote Link to comment Share on other sites More sharing options...
ronnieb Posted April 14, 2014 Author Share Posted April 14, 2014 Thanks, just started to play with the idea. First time i peaked under the car, for this, is today, the rear, i think i can have a riser made for the lower end of the strut to mount into. Simple steel fabrication or if there is a prefab, makes life easier... I will investigate some more for the front any web sites to look at or pointing in a good direction, would be great.. Will do more research.... I have to say, as i never had a subaru and always had a truck, they have designed the underneath of the car amazing for clearance... Thanks Quote Link to comment Share on other sites More sharing options...
