elgigante Posted June 13, 2014 Share Posted June 13, 2014 (edited) Never drove a ea82 until I purchased one. I dont know how they run when running good. When driving on the highway when I get to about 4k the car feels like boost kicked in. Is this right? Also sometimes the green turbo light will stay on until I punch the throttle. I thought it only goes on when im boosting Edited June 13, 2014 by elgigante 1 Quote Link to comment Share on other sites More sharing options...
jono Posted June 13, 2014 Share Posted June 13, 2014 is this the same vehicle you have lots of posts on ?? My 85 EA82T boost light came on about 2500rpm, but only when conditions were right - a vacuum/boost gauge really helps to drive a turbo by. Should feel the power (be careful ) about 2500 up to about 4000 on most EA82T. Only when something was wrong with my blow of valve install did I only feel power starting at 4000rpm - hated it, nasty slap in the back and 1500rpm too late, snails were sniggering at me Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 13, 2014 Share Posted June 13, 2014 Don't turn up the boost or you will blow it up. Good luck Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 13, 2014 Author Share Posted June 13, 2014 I have the wastegate connected to the turbo it self as I saw on a rx when I went to pick n pull, is this not correct? Or should I connect the waste gate duty supply? Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 13, 2014 Author Share Posted June 13, 2014 I have the wastegate connected to the turbo it self as I saw on a rx when I went to pick n pull, is this not correct? Or should I connect the waste gate duty supply? And if I do connect it will this help? Quote Link to comment Share on other sites More sharing options...
jono Posted June 13, 2014 Share Posted June 13, 2014 mine was direct on 85,86. 87 models got solenoids etc to interfere orcontrol things better 1 Quote Link to comment Share on other sites More sharing options...
Uberoo Posted June 14, 2014 Share Posted June 14, 2014 Don't turn up the boost or you will blow it up. Good luck I'm sure it would run 20 PSI once. Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 14, 2014 Author Share Posted June 14, 2014 (edited) Yea how would I hook it back up? The straight part to turbo? Bottom to waste gate? Back of the solenoid to the vacuum on manifold Edited June 14, 2014 by elgigante Quote Link to comment Share on other sites More sharing options...
jono Posted June 14, 2014 Share Posted June 14, 2014 for the 87.5 spider turbo ..... the T off the device (mine has same red part number label)goes to the wastegate diaphragm, so this is the bit that is off to right angles where the other two go through device in a straight line OK ?? The straight line on device all on its own goes or rather comes from the turbo alloy housing just in front where outlet hose for compressed air comes out of turbo, It has a small inline valve for either restriction or flow direction. The other end, closer to the T off is like a vent outlet and ends up witha T fitting and goes to intake boot, the other end of that T ties into a metal tube coming off inlet manifold tree of tubes, comes around corner and its end points right at turbo Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 15, 2014 Author Share Posted June 15, 2014 Thats confusing, you have pictures? Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 20, 2014 Author Share Posted June 20, 2014 Any help? Quote Link to comment Share on other sites More sharing options...
jono Posted June 20, 2014 Share Posted June 20, 2014 (edited) yeah, your picture - lets call each of three pipes on the solenoid a port? the hose still fitted in pic? - the empty end goes where this next few lines takes it- "The straight line "port" on device all on its own goes or rather comes from theturbo alloy housing just in front where outlet hose for compressed aircomes out of turbo, It has a small inline valve for either restrictionor flow direction". Fit that and you have two hoses to find and fit at the other end. The port coming off at right angels to the other two ports, one you have just found a connectuion for abovee?? Sorry, just read that - needs rewriting ... At the other end where you see two ports to the solenoid, one is straight out, the other goes off at right angels, 90 degrees - OK, got it ? The straight out is really a vent off or bleed off from the solenoid so this connects to the intake rubber boot after the afm, somewhere near where the PVC hose fits up. It also has a T in this line, close to where you hook it into the rubber intake boot. Maybe for this stage forget the T in line and just connect it to the boot ? into a metal tube coming off inlet manifold tree of tubes, comes aroundcorner and its end points right at turbo Edited June 20, 2014 by jono Quote Link to comment Share on other sites More sharing options...
