carfreak85 Posted May 26, 2004 Share Posted May 26, 2004 I bought a hoist last night and proceeded to pull my EA81T out of the engine bay. She complained a little about having her heart removed and she still needs to be releived of her P/S lines, but she'll be out soon. The shop I'm taking the engine to probably will use a rebuilt short block, but since I would like to keep a numbers matching car, I think I will give them an extra block and keep the original so I can have that rebuilt and eventually put some modded heads on it. So what should I do to the car while the engine is out? I want to replace the hoses with silicone (No fancy colors, just black or grey), but what else should I mod or replace while the engine bay is empty? I will start looking for a WRX or legacy turbo and maybe have an exhaust fabbed up. Besides that, what are your suggestions? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 26, 2004 Share Posted May 26, 2004 well if this was a manual, I'd say lighten the flywheel but since its a automatic.....ummm the only good advice would be to get rid of the auto but you mentioned keeping a numbers matching car so I don't think you'd be doing that anytime soon. Fab up a cold air intake, work on the ignition by using a bigger coil, bigger radiator with dual electric fans, maybe an intercooler and if you use one, put a boost controlled fan on it. Other than that, I can't think of anything you could really do to it besides raise the boost and readjust your timing. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted May 26, 2004 Author Share Posted May 26, 2004 Well, the one thing I haven't done to keep in numbers matching WAS to change the tranny. It's now holding a 5spd D/R under it's belly. Also has a MSD coil, and I'm about to put a manual boost controller on it. I think the radiator will be able to handle the increased temps, but I may go to aftermarket FAL or another companie's big fat fans. Intercooler goes on after the turbo swap. Anyone else with an opinion? Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted May 27, 2004 Author Share Posted May 27, 2004 Bumpidy rump! Quote Link to comment Share on other sites More sharing options...
