Stopped running, still turns over?
i have a 1995 Legacy L 2.2 SFI? While driving it it suddenly got Hot and water spewed out the drivers side in the engine compartment. From where? So I refilled the radiator with about a gallon and then continued on when suddenly it it stalled. I checked and filled the oil. It was down 3/4qt. Now it only turns over and will not start? Where do I start? Thank you.
Sounds like a t-belt failure. Water pump probably went out and kicked the t-belt off. I would Start by pulling the drivers side inspection cover and take a look
Sound reasoning. It is a 95, 2.2 motor, so it is non interference. Good thing is.........if Tbelt broke, the valves will not be damaged.
  • Like 1
