1996BlackBauer Posted September 2, 2016 Share Posted September 2, 2016 So I was leaving my house today, turn out on to the main road, shifted into second, got on it a little bit to hear it wind up, nothing more then 4k if that, shift into 3rd, hear a pop noise, thought the engine was running, no throttle input, pulled it out of gear, tried to do it again, it was dead, coasted into a parking lot. I then tried to restart, sounded a little weird, but turned around just fine, but nothing at all. I peaked in the crack of the timing cover the belt spins, so nothing is locked up. I'm thinking I might have skipped a few teeth. The car in question is a 1996 Impreza Outback sport, with an EJ22, it is completely stock at 216K. Any input would be great, thanks, Harold. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted September 2, 2016 Share Posted September 2, 2016 Look further at the timing belt, I bet it is broken. Same happened to my 95 with 2.2 motor. Quote Link to comment Share on other sites More sharing options...
987687 Posted September 3, 2016 Share Posted September 3, 2016 Fortunately your engine isn't interference, so if your timing belt broke nothing got hurt. Pull the driver side timing cover cap, it's held on with three 6mm bolts, you'll need a 10mm wrench. Quote Link to comment Share on other sites More sharing options...
1996BlackBauer Posted September 4, 2016 Author Share Posted September 4, 2016 Thanks for the heads up, I was able to take the whole cover off and the belt isn't broken. but no matter how many times I turn the engine the timing marks never line up. so it had to of slipped. I made a video though. might be better that way. Quote Link to comment Share on other sites More sharing options...
987687 Posted September 4, 2016 Share Posted September 4, 2016 Looks like the crank and passenger side marks line up, but the driver side is 90 degrees out. That's not good. Fortunately, no damage was done since it's a non-interference engine, putting the belt back on properly will bring it back to life. You need to figure out WHY it jumped time, though. Make sure your tensioner isn't loose and flopping around. Quote Link to comment Share on other sites More sharing options...
mikec03 Posted September 4, 2016 Share Posted September 4, 2016 +1 for the tensioner. You need to change all the timing components every 60K miles. If that wasn't done, then now is the time. Isn't it great to have a non interference engine! Quote Link to comment Share on other sites More sharing options...
1996BlackBauer Posted September 4, 2016 Author Share Posted September 4, 2016 Very cool, I'm super glad that there was no damage. I hate to be that guy, but between the two engines I did work on over the winter, I have a timing belt with 20k on it, and enough good pulleys to do all the work. I'm going to clean up all the oil down there to, I have a feeling that doesn't help at all. I have fixed the leak, but never cleaned it all up. Quote Link to comment Share on other sites More sharing options...
1996BlackBauer Posted September 5, 2016 Author Share Posted September 5, 2016 So I replaced the belt with a used one, after looking my my buddies car, it had just under 15k on it, since the last belt was done, with all new pulleys, The parts that I got my my friends car are all Aisin parts, Pulleys, belt, and tensioner, and they all have the same mileage. So I feel pretty good about that, I'll probably do a real timing Job when I do the Clutch some time next year, but for now the car runs great. I also pulled the plugs, checked the gap, and replaced a suspect spark plug boot due to burn on the rubber. All in all, even with messing around with steam cleaning the whole front side of the block, so I don't have to worry about oil getting everywhere again, it probably took 4 hours. I was even able to get it done without removing the radiator. Thanks for all the help guys, and thank you Subaru for not having an interference engine in my car, lol. Quote Link to comment Share on other sites More sharing options...
