zubricki Posted September 23, 2016 Share Posted September 23, 2016 Hi everyone, I recently got a 2008 Impreza hatchback with the 2.5L engine and a 5 speed manual transmission. About a week ago I noticed a "rubbing" noise when I depressed the clutch pedal. This being my first car with a manual transmission I didn't think much of it, it was pretty faint. Today, however, that same noise was much more noticeable (I usually drive with the radio on so I'm guessing its been there all along and I just didn't notice it. Now it's a louder rubbing noise and sometimes even whines a little bit. Again, only happens when depressing the clutch, let the pedal out and the noise goes away (or at least gets significantly quieter, maybe I'm paranoid but I swear I can hear it a little just sitting in neutral with the pedal out). So here are my questions: 1. Based on my research thus far it seems to me like this is being caused by a throw out bearing on the way out. Does this seem right? Car has 105k miles on it. 2. Is this something I can let go for a while? I have a good transmission mechanic and can afford the repair right now, but as this is my first manual transmission I would rather continue to make my learning mistakes now then get the throw out bearing / clutch replaced. 3. Seems like this would be a good opportunity to get the clutch replaced, any thoughts? 4. Are throw out bearings considered a wear item or could I have ridden the clutch too much in a matter of weeks to make it die? Thanks in advance for the advice. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 24, 2016 Share Posted September 24, 2016 A failing TOB will eventually cause major damage when it locks up entirely. You generally don't have long when it starts making noise. A couple weeks at most. Quote Link to comment Share on other sites More sharing options...
zubricki Posted September 26, 2016 Author Share Posted September 26, 2016 Fairtax, thanks for the input. I've arranged to get it to my transmission mechanic next week and will avoid driving it in the meantime. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 26, 2016 Share Posted September 26, 2016 uh - if it hasn't been done, you need a timing belt service too. Quote Link to comment Share on other sites More sharing options...
zubricki Posted September 26, 2016 Author Share Posted September 26, 2016 Texan, thanks for the tip. Timing belt and water pump were done upon purchase of the car (103k) and head gaskets were inspected by a trusted Subaru mechanic. I'm hoping after this throw bearing / clutch job I can get some good miles on it before the next major issue. Quote Link to comment Share on other sites More sharing options...
