jonbfish Posted October 24, 2016 Share Posted October 24, 2016 I have a 98 Legacy L with ABS. I think I have a bad wheel bearing (had to replace an inner tie rod recently so thinking the play wore it even though it sounds like the noise is coming from the other side) and started to take it apart. When I got to the ABS sensor the bolt came out easy enough, but how does the sensor body come out? There is a small gap at the bottom that I tried to wedge a screwdriver in to see if it would pop away from the knuckle, but a youtube I saw said to not do that because you will break it. Any suggestions? Went ahead and put it back together as its my only car but I know its going to need replaced soon. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted October 25, 2016 Share Posted October 25, 2016 Spary PB and tap it so it starts to twist. Back and forth a few times then it will pry out. O. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 25, 2016 Share Posted October 25, 2016 Don't bother with it. You don't need to remove it to replace the bearing. Quote Link to comment Share on other sites More sharing options...
jonbfish Posted October 25, 2016 Author Share Posted October 25, 2016 Don't bother with it. You don't need to remove it to replace the bearing. How so? Should I unplug it somewhere and just leave it in? I am going to have to take it somewhere to get the bearing pressed in, is it far enough out of the way for that? Quote Link to comment Share on other sites More sharing options...
jonbfish Posted October 29, 2016 Author Share Posted October 29, 2016 Also, is it preferred to remove the pinch bolt or just take the ball joint out with it? Quote Link to comment Share on other sites More sharing options...
jonbfish Posted October 29, 2016 Author Share Posted October 29, 2016 Would a 12 ton press be enough to do the wheel bearings? Looked at one at Northern Tools this morning. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 29, 2016 Share Posted October 29, 2016 There's a plug on the wire, it should be just inside the frame rail on that side. 12 ton may not be enough for these. They get pretty stuck in there, especially if you live in the rust belt. Quote Link to comment Share on other sites More sharing options...
jonbfish Posted October 29, 2016 Author Share Posted October 29, 2016 I do live in rust country unfortunately. I'm having trouble getting the hub off still. Pinch bolt feels like its going to break, and the castle nut is spinning the bolt on the ball joint. I've been searching the forum and looks like its common and no easy solution. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 30, 2016 Share Posted October 30, 2016 (edited) No, unfortunately there's no easy way to pop loose those ball joints. If the castle nut is spinning the stud, try putting a jack under the control arm to push up on it and see if it will hold the stud just enough to get the nut loose. You a Jon B. fan? Edited October 30, 2016 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
