YJ4000 Posted November 1, 2016 Share Posted November 1, 2016 (edited) Hi all, I've got a 01 outback 2.5. It seems to cut out but not stalling when it should be shifting. Buzzing sound at trans w/ koeo, it stops just as I open the throttle than will start past there. Found trans code 31. TPS tests good. Ground and 5v there. Now what? Thanks in advance, Ryan Edited November 1, 2016 by YJ4000 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 1, 2016 Share Posted November 1, 2016 is the trans pan dented? Quote Link to comment Share on other sites More sharing options...
YJ4000 Posted November 2, 2016 Author Share Posted November 2, 2016 I will check tomorrow, It's not mine some one asked if i could repair it for them. Also it has 240K. Thanks, Ryan Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 2, 2016 Share Posted November 2, 2016 How did you test the TPS? Whats the voltage at idle with the key on engine off? It sounds like it's not adjusted properly. Quote Link to comment Share on other sites More sharing options...
YJ4000 Posted November 3, 2016 Author Share Posted November 3, 2016 I just got off the phone with the owner and he said he put a TPS on. I will check the adjustment tomorrow. Thanks, Ryan. Quote Link to comment Share on other sites More sharing options...
YJ4000 Posted November 4, 2016 Author Share Posted November 4, 2016 (edited) I adjusted the TPS and it's better. The car is running the way it was before he started changing parts. It sometimes stumbles off idle and feels like it's skipping and set the CEL. P1507. I've read about the nuteral safety switch but this has an auto and they have sticks? Edited November 4, 2016 by YJ4000 Quote Link to comment Share on other sites More sharing options...
