Getting outer tie rod out of knuckle
XT6, no rust
Sprayed with YIELD and wailed on with a few pound (large) steel mallet.
Any chance of getting this thing off without heat?
I'll throw a hefty digging bar at it next.
Maybe illl break the torch out but if I do that it'll singe the tie rod boot making saving the tie rod pointless anyway and I could just unthread it from the inner tie rod in the first place.
Soak with CRC or other penetrate.  After loosening the castle nut, spin to top of threads.  Slightly hammer on top of nut.  Be careful not to damage threads.  Sometimes helpful to bang on side of hub.   HTKYSA also mentions prying with 2x4 using leg.   Bang, bang, pry pry.
  If that does not work, try a pickle fork ... careful not to damage rubber.
Ill try a 2x4 or digging bar and some leverage.
I used Yield, a high quality penetrant some shops and machinists use
Hitting the nut will compress and damage the threads, hitting the threads will compress and mushroom those. Seen that lots of times, this one is definitely that tight. It's not budging with a very heavy steel mallet on the rod next to the knuckle.
