jono Posted August 25, 2017 Share Posted August 25, 2017 Has anyone got measures for both series.? How much wider is an EA82 than EA81 in the rear end? Would not hurt to compare front tracks too! Quote Link to comment Share on other sites More sharing options...
jono Posted August 26, 2017 Author Share Posted August 26, 2017 Roughly 80 mm wider in the rear end, 70 or 75 seems to be in the increased width of rear trailing arm mounting point on the tubular subframe Quote Link to comment Share on other sites More sharing options...
jono Posted August 26, 2017 Author Share Posted August 26, 2017 Reason is looking at fit rear sway bar from ea82 to ea81 ....looks to be needing some thought and 40 mm cut off each side to start the idea Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 26, 2017 Share Posted August 26, 2017 the distance between the trailing arm pivots will be more critical to compare. That's the measurment that determines where on the arms the mounts would need to be to keep the swaybar "arms" in line with the trailing arms. Quote Link to comment Share on other sites More sharing options...
jono Posted August 26, 2017 Author Share Posted August 26, 2017 Just what I was thinking. Some clever bracketry be needed to carry this out. Need to chop ends first to even get it in there for thinking time. Thanks. Wondering if I am Robinson Crusoe on this idea attempt? Quote Link to comment Share on other sites More sharing options...
dfoyl Posted August 26, 2017 Share Posted August 26, 2017 It's been done several times. I believe Tony Reig (owner of the red Brumby-turned-BRAT) has an EA82 bar on his Brumby and could show you what needed to be modified. Quote Link to comment Share on other sites More sharing options...
jono Posted August 27, 2017 Author Share Posted August 27, 2017 Oh good. All I need is for him to look in Quote Link to comment Share on other sites More sharing options...
