EJ206 long block into 2004 WRX?
No replies to this topic
#1 matt167
matt167
    Certified Subaru Nut
  • 962 posts
  • Prattsville Ny
Posted 19 September 2017 - 04:21 AM
Finally got an engine for this pile so I can get it out of here. Problem is the Importer sent an EJ206 long block instead. I called the importer and their response was, it's compatible. Change this and that and it works. In the end I got them to send a partial refund because of the mis listing and it was pretty obvious they were not willing to make it right. I knew the cam and crank sprockets would likely need swapped and planned on that, but water neck and a couple other things he noted were different too. The crossover tube is very different which is why I checked the codes in the first place. It also does not have an oil cooler?
Are the cam profiles close at least? I know it's a 9:1 compression and was rated at 255 HP. How much tuning is this going to require to keep it from blowing up or spinning a rod bearing?
I know they are obviously doing this so they don't break down more valuable EJ205's since TT setups won't fit LHD cars
Edited by matt167, 19 September 2017 - 04:25 AM.
