EA82T performance upgrades
7 replies to this topic
#1 4moretoyz
4moretoyz
    New User
  • Pip
  • 5 posts
  • Phoenix AZ
Posted 22 September 2004 - 04:38 PM
Hi All:
I have an Ea82T (with the small rectangular boost hat that says awd turbo), I think it's out of a late 80's Loyale or brat. It's installed in a large 4 seat sandrail. it's stock and uses ALL stock components, including electronics, except a very open intake and open exhaust. I need about 20 to 40 more hp out of it any ideas? I was thinking a boost controller, but worry about the mapping and not delivering enough fuel, or going into "limp" mode. So any idea in cheap to more expensive order would be greatly appreciated.
Thanks
#2 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 22 September 2004 - 04:45 PM
lets see.... for boost
i use a saab 9000 apc boost controller stock it gives you 10 psi
if you tinker with it.. as much as the ihi turbo can do
plus it has knock sensing that reduces boost if it hears knocking
for fuel i use a megasquirt d.i.y programmable fuel injection controller very nice.
no more maf complete tunability the base program code for it has recently undergone alot of .. alot of changes
so it does a lot of stuff now...
including ignition control
try www.msefi.com
and for ignition..
well i don't have a distributor.. btw this is a ea82t turbo in a 87 wagon ...
i use a modifed version of the ford edis distributorless ignition system
that is also controlled by the megasquirt
#3 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 22 September 2004 - 06:13 PM
why not just go ahead and go to a stand alone?
#4 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 22 September 2004 - 06:14 PM
uh who... him or me??? i think i did lol
#5 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 22 September 2004 - 06:23 PM
sorry I should have made that clearier, I meant him.
#6 4moretoyz
4moretoyz
    New User
  • Pip
  • 5 posts
  • Phoenix AZ
Posted 22 September 2004 - 06:30 PM
Hey JWX (Lonely driver?) sorry to seem uninformed, but stand alone what, Boost controller, electronics (such as Link, etc.)?
Thanks
#7 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 22 September 2004 - 06:36 PM
a full fuel/spark controler is what I'm talking about.
(I got the name from an anime called Initial D, I thought it was funny at the time about year or so ago. and I'm just to lazy to think of something top change it to)
#8 RallyKeith
RallyKeith
    Got Subaru(s)?
  • 1,500 posts
  • Reading, Pa
Posted 22 September 2004 - 07:06 PM
First Thing I'd do is get the $150 Delta Cams. Everyone says they make the motor scream. Do a search for Delta Cam on here and you should find lots of info. That combined with some form of boost controller will give you what you are looking for. Be careful not to go with too much boost. If your engine uses a hot wire MAF sensor then it will not like more than 9psi for sustained periods. The ECU has a built in fuel cut if it senses more than 9psi for some amount of time.
Keith
