beezer Posted November 17, 2004 Share Posted November 17, 2004 I have a 1992 2.2l legacy wagan. The car has been running excellent until today. Well actually yesterday the car died once while coming to a stop. This morning when I started the car the revs didn't go up like it normally does. I turned the car off then turned it back on and it seemed fine. Tonight the car started to hesitate mostly between 1000 rpm to 3000 rpm. The car idles now around 1500 but will occasionally drop down or rise up. The check engine light is on and I found some codes but I'm not sure what they mean. The codes are 12 15 35 24. Not sure which one of these are old. I think it might be the alternator but not sure. Hope someone can help. Thanks Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted November 17, 2004 Share Posted November 17, 2004 Do a search on the board for "legacy codes" and you should be set. I would clear the codes first and then see if they come back. There is a chance you have some old codes stored. Pull the #14 fuse and leave it out for a few hours, then re-install it. Drive your vehicle as usuall and then check for codes. These codes you should be able to cross reference with the info you find on the board. Hope this helps. Josh please give this person the link to the codes if you have it handy. Quote Link to comment Share on other sites More sharing options...
beezer Posted November 17, 2004 Author Share Posted November 17, 2004 Thanks. I left the car sit over night, when I started it this morning there was no check engine light on, and the car seemed to be running fine. I thought it was a coincidence that the car didn't act up until the wife tried to move the car for me. She hopped the car down the road a little ways stalled it a little, maybe I will just have to revoke her subaru driving privileges. Oh well I'm sure the problem will come back again. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 17, 2004 Share Posted November 17, 2004 If you checked the codes after the light was on, right them down, clear the codes, drive the car, and see what, if any come back. Instructions how to do all that, and what the codes mean are on my site. Quote Link to comment Share on other sites More sharing options...
Cougar Posted November 17, 2004 Share Posted November 17, 2004 Here is a link that may help you with the trouble codes. I agree that the alternator may cause this kind of thing but the trouble codes may be telling you something else is going on. I would make note of the old codes and then clear the ECU to see if more codes come back. http://www.troublecodes.net/Subaru/ Quote Link to comment Share on other sites More sharing options...
