subynut Posted November 21, 2004 Share Posted November 21, 2004 Hey Guys, I gotta question. Me Suby has this rattle kind of sound. Kinda hard to explain. It appears to be comming from the drivers side. It dissapears on acceleration and shows up on decelleration and at idle. It's not lifter tick, that's on the other side where I'm trying to figure out which lifter is being stubborn. I did the ol' breaker bar to the ear trick and found that it's the noisiest in the area of the ditsy. The cams are 180 apart, and lined up with the marks on the flywheel. I checked the timing and it's bouncing around 10 deg btdc. Vac guage is solid at 16" at 800 RPM. Here's an MP3 of me Suby running. There'a lifter tick, an exhaust leak and a little breeze amongst the rest of the sound of the engine. Don't know if you can hear it or not. Any ideas? Wave4.zip Quote Link to comment Share on other sites More sharing options...
Skip Posted November 21, 2004 Share Posted November 21, 2004 a loose timing belt on the driverside will cause the distributor drive gears to click (could cause the timing to vary also) May be the reason behind the accell decell change. Heat shields also will rattle like this. Quote Link to comment Share on other sites More sharing options...
robaru Posted November 21, 2004 Share Posted November 21, 2004 Spark plugs threaded in snug? I just spent an hour last night searching for a rattle that ended up being the silly plug. Quote Link to comment Share on other sites More sharing options...
subynut Posted November 22, 2004 Author Share Posted November 22, 2004 Ok, I'll check those out. Hummmmm loose t-belt.......... Quote Link to comment Share on other sites More sharing options...
subynut Posted November 23, 2004 Author Share Posted November 23, 2004 Yup, loose t-belt BUT, I have a stripped bolt(more like the heli-coil stripped out) that holds one of the tensioners in place (Drivers side). When I originally loosend the tensioner bolts they were very difficult to crack loose. When I went to retighten them after replacing the belts, one of the bolts wouln't tighten up properly. Thought that was rather strange, guess my fear was right. So, NOW what? It appears I cannot run with just one of the bolts cause I can move it by hand with the remainder bolt tightend as much as I dare. Quote Link to comment Share on other sites More sharing options...
subynut Posted November 24, 2004 Author Share Posted November 24, 2004 Ok, I was talking to one of my co-workers and he sugested just going one size up and just tap the aluminium itself and forget the heli-coil. Would that work? For how long? Quote Link to comment Share on other sites More sharing options...
