96 Legacy valve cover gaskets.....
3 replies to this topic
#1 bgambino
bgambino
    Subaru Nut
  • 710 posts
  • new york
Posted 12 December 2004 - 08:17 AM
I have done tons of work on GL's Dl's and my loyale's...but virtually nothing on a Legacy
I think my niece's legacy has leaking valve cover gaskets(just washed it yesterday and waiting for it to leak)
Any tricks to replacing?...seems to be only 3 bolts (interesting that they are not around the perimeter)
triied to tighten but could not move.....do the bolts ever get stuck?
what about torqueing in the new ones?
OEM or carquest brrand?
thanks...this is an awesome forum to have
#2 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 12 December 2004 - 01:16 PM
They are easy to replace. I think the last bolt on the fire wall side is a little hard to get at but not impossible. The main gasket comes in a kit with three bolt washer-gaskets.
The torque value is very low, around 15 ft pds if I remember well. I'll check in my Haynes manual tomorrow if nobody volunteers the exact torque value.
Strange think though that could account for why you could not torque the bolts any further, the bolts seems to hit bottom at about the same time you reach max torque value. I think it might be a safety feature. If you torque the valve cover too much it could deform and spring a leak.
Good luck.
Edit : I would'nt mess with anything other than OEM for this. It's not very costly in the first place and perfect fit is a must.
#3 frag
frag
  • 1,777 posts
Posted 12 December 2004 - 05:07 PM
I was way off. Chilton's gives 5 ft-lb for the cover bolts. Remember the covers are aluminum.
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 12 December 2004 - 05:21 PM
agreed.
