disck brake conversion questions
13 replies to this topic
#1 mtnman38
mtnman38
    Subaru Fanatic!
  • 373 posts
  • kitsap county
Posted 13 December 2004 - 09:18 PM
Can anyone tell me if you can use the rotors and calipers from the front of an 86 gl wagon ea82 for a rear disk brake conversion for my 84 4wd hatch ea81 in theory all I would need is a backing plate from a turbo wagon or am I way off do you think this is possible pm me with details
#2 sportsterbrat
sportsterbrat
    USMB Regular
  • PipPipPip
  • 102 posts
  • Belton SC
Posted 13 December 2004 - 10:19 PM
There is a nice write up in the USRM thats what I went by . Works great!
#3 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 13 December 2004 - 10:46 PM
You cant use the front rotors and Caliper on the rear unless you fabricate a new bracket for the calipers. The rotor is larger in the rear, and the calipers are alot different.
In order to convert your hatch, you'll need the rear rotor, caliper & Backing plate from any 4WD Turbo EA82.
-Brian
#4 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 14 December 2004 - 03:05 PM
-Brian
Has to be 4WD turbo to fit on EA81? I thought it was any 4WD with rear discs.
#5 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 14 December 2004 - 04:09 PM
but only turbos got rear disks
#6 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 14 December 2004 - 04:20 PM
Herm... could have sworn I've seen an XT4 MPFI NA with rear discs in a junkyard.
#7 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 14 December 2004 - 07:43 PM
hmm maybe somebody swapped them? or maybe it was an option?
#8 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 14 December 2004 - 10:44 PM
could be either. we should know by now that there is no such thing as "only" as far as which cars came with which. :)
#9 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 15 December 2004 - 10:37 AM
the rear discs were an option if they didn't come on a turbo car. You can use the discs from a 2wd EA82 BUT you'll need the 4wd hubs to make it work.
#10 mtnman38
mtnman38
    Subaru Fanatic!
  • 373 posts
  • kitsap county
Posted 21 December 2004 - 11:17 PM
Hey thanks all just completed conversion went supa smooth much thanks
#11 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 22 December 2004 - 12:24 AM
Another satisfied rear disc swaper :drunk:
#12 sportsterbrat
sportsterbrat
    USMB Regular
  • PipPipPip
  • 102 posts
  • Belton SC
Posted 22 December 2004 - 12:29 AM
Me too Worth their wieght in gold!
#13 scrapdaddytatum
scrapdaddytatum
    the subaru surgeon
  • 790 posts
  • charlottesville, virginia
Posted 22 December 2004 - 07:05 PM
can i get a parts brake down
i want to put rear disc on my 83 lift ea81 wagon
#14 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 22 December 2004 - 08:03 PM
Check our Repair Manual. There's an extensive how-to written by me. The swap is very basic and about as bolt-on as you can get.
Rear disc's came on a bunch of different EA82 models. Like N/A GL10's, XTs and was an option for any EA82 if requested. Its just that ALL turbo EA82's will have disc brakes. The reason I tell people to look for turbo EA82's cause 100% of them will have rear disc's. If your car is 4WD, you will need 4WD rear disc's. If your car is 2WD, you'll have to get disc's from a FWD only EA82.
-Brian
