turbo a na 2.2?
10 replies to this topic
#1 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 19 August 2003 - 12:42 AM
can you just stick a turbo on a 2.2 from 90-95, if its na? will the stock computer be fine with stock, or higher boost levels?
#2 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 19 August 2003 - 09:43 AM
NO! You'll blow holes in the pistons. Turbocharged engines have a lower mechanical compression. If you force feed a na engine - high compression - bad things happen very quickly.
You will need to replace the pistons, maybe the crankshaft, and certainly the injector nozzles - they need to be bigger to feed more fuel to join the force fed air.
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 19 August 2003 - 11:17 AM
a properly done turbo kit will work for low boost without changing engine internals.
Key words, properly done, and low boost
www.forcedairtech.com
www.pdmturbos.com
#4 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 19 August 2003 - 01:56 PM
I HAVE HAD A 10:1 COMPRESSION TURBO CAR WORK GREAT! and there are a couple 9.5:1 compression ea82s running around with great results, on stock computer and internals. im just wondering about the fuel injectors and computer. does the maf sensor just measure the air coming, even if its boosted? trust me the high comp will be fine:banana:
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 19 August 2003 - 04:14 PM
yes it measures the air coming in. You will need some form of boost control as well as a/f control, and really should have timing control as well, but for low boost you can probably get away without it.
#6 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 19 August 2003 - 05:27 PM
by af controll? you mean something like a super afc? and timing controll, like a retard when boost hits? it'll be stock boost, for a while, with the legacy turbo, and an intercooler and bov of some sort.
#7 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 19 August 2003 - 07:55 PM
the s-afc yeah.......something to that extent....
#8 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 19 August 2003 - 08:44 PM
Why couldn't it be done? Subaru doesn't make any crappy engines, just the turbo ones are better...
If Sport Compact Car can turbocharge an 11.5:1 comp engine like the Matrix XRS, then you should have no problem doing 9.5:1...
I couldn't agree with Legacy777 more, though. It has to be properly done. With proper tuning, the engine should be as durable with the boost as without it. :headbang:
#9 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 19 August 2003 - 10:41 PM
Well the matter of the pistons staying in one piece and not melt has additional factors beyond A/F, timing and CR. There is also the matter of how the pistons were constructed. I believe that the stock pistons are either investment cast or die cast. Now this is fine for stock or mildly boosted application. Now when you start dealing with high boost and add a high CR, well you're going to need a set of forged pistons.
#10 greg donovan
greg donovan
    USMB Regular
  • PipPipPip
  • 60 posts
  • Fargo, ND
Posted 20 August 2003 - 01:44 AM
if you keep boost under 10 psi and use a good piggyback system and add a good intercooler and a water sprayer on it and an aquamist water injection system you will have no problem turbocharging a ej22. this is the advice i got from paul eklund owner of primitive racing and a pioneer of the hybrid turbo imprezas in the us. this wont get you alot of hp but off boost it will have more power than a turbo motor.
greg
#11 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 20 August 2003 - 09:05 AM
thats what im thinking. they make turbo motors 8:1 so even if you did run crappy gas you'll prolly be ok if you keep your foot out of it. it should be fun, maybe i'll relieve the combustion chamber a bit when i have the heads off.
