I'm thinking about doing a major parts swap on my 1990 Legacy wagon. Its currently front wd, auto trans. I'm considering, if the price is right, doing a swap of a turbo legacy engine, and a 5spd trans. I already know of a source for the awd parts, and I know that bolts up with a trans from an awd car. Is this crazy to consider, or should I find a better way to spend my $$?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EJ22 motor swap
Started by
1990legacy
, Jan 16 2005 06:32 PM
6 replies to this topic
#1
Posted 16 January 2005 - 06:32 PM
#2
Posted 16 January 2005 - 07:24 PM
I am pretty sure that you can not turn a FWD into an AWD. You might want to give legacy777 a holler.
He would be the one to know.
Maybe when you are done with your swap, you could lend me a hand shoehorning the WRX STi drivetrain and exhaust into my 90 legacy wagon.
#3
Posted 16 January 2005 - 07:44 PM
you can turn fwd cars into awd as long as the mounting holes for the rear diff and suspension is there, but be sure to match rear diff and front (tranny) diff. ratios, the turbo legacys are 3.70 i believe, so make sure you grab the rear diff. out of the turbo legacy car. you also might have to shorten or lenghthen the driveline. and of course grab the pedal box and clutch cable, or if hydro clutch grab the clutch master cylinder and all that stuff. thats about all that i can think of. good luck.
~Josh~
~Josh~
#4
Posted 17 January 2005 - 09:31 AM
The chassis has all the bolt holes there.
It can be done, I did it. If you plan to use a turbo legacy transmission, expect a little more difficulty, because you must drill a hole in the firewall for the clutch master cylinder.
I've got a full detailed write-up on my swap
http://www.surrealmi.../swap/swap.html
#5
Posted 17 January 2005 - 11:19 AM
I could have sworn I saw a post where someone asked the same question and a few people answered that it could not be done.
Can it be done on all suabrus?????
#6
Posted 17 January 2005 - 12:45 PM
Are you referring to the swap I did, and converting FWD to AWD, or AT to MT, or both?
I'm not sure what the other thread said, but assuming you get the same suspension and components for the same model year you're looking to swap, it should work fine, and all the holes will be there.
#7
Posted 17 January 2005 - 01:18 PM
and in most cases technically it does not pay to do it. That said it could really be a learning experience and if you have more time than money it could be fun.
When I think back I had one pickup that had three entire sets of different running gear while it was around for 10 years. It was crazy to do this to an old truck but my friends and I enjoyed it.
