Thermostat replacement 95 Legacy 2.2L
7 replies to this topic
#1 henry_rap
henry_rap
    New User
  • Pip
  • 8 posts
  • Allentown
Posted 24 January 2005 - 12:00 AM
Do I need to drain both the radiator and the block when replacing the thermostat or can I get away with draining the radiator only. I can't flush the system right now but I think I need to replace the thermostat. Thanks.
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 24 January 2005 - 12:21 AM
What makes you think the thermostat is bad?
If you do need a new one just draining the radiator about a third will be enough.
#3 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 24 January 2005 - 04:31 AM
Ah Glen, the EJ 22 is a bit different than what you are used to I believe.
The T-stat is under a goose neck that is on the block on the end of the
lower
(not upper) radiator hose.
I'm afraid most of the system will need drained.
Catch it and filter it through a clean cloth when putting it back in.
Follow the burping proceedure of having the front higher than the rear, using the upper rad hose as a fill point, there is an excellent post by Setright on this method.
#4 bearbalu
bearbalu
    USMB is life!
  • 182 posts
Posted 24 January 2005 - 12:49 PM
They system can be drained directly at Thermostat housing by putting a big aluminum trey and undoing thermostat bolts. Draining the radiator first might prevent a few splashes...When thermostat comes out, it drains most of the engine block too.
#5 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 24 January 2005 - 02:06 PM
Oops! Thanks for the notice on that Skip and keeping me straight. I haven't worked on the newer models yet, so I am unaware of changes that were made. I guess I better stick with info I know is correct before I pass out advice.
#6 henry_rap
henry_rap
    New User
  • Pip
  • 8 posts
  • Allentown
Posted 24 January 2005 - 04:43 PM
I getting luke warm heat not hot and the windows are fogging up something fierce. Any ideas of why the windows are fogging up? Thanks for the help.
#7 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 24 January 2005 - 05:49 PM
Since you state that windows are fogging up and if you smell something like coolant then it sounds like there is a leak in the heater core I'm sorry to say. You will have to replace it probably. Not an easy job. You may want to have a pro look things over. Hopefully you don't have a head gasket leak also.
#8 henry_rap
henry_rap
    New User
  • Pip
  • 8 posts
  • Allentown
Posted 24 January 2005 - 08:10 PM
Thanks Cougar.
I do notice an occasional coolant smell. I will have it looked over by a pro. I take it by your comment that the heater core is not a fun thing to replace.
