Smpol19 Posted February 7, 2005 Share Posted February 7, 2005 Anyone found a source for the dashboard illumation lights, spacificly the rear defrost button on my Impreza. Its a little light mounted in a peice of rubber that slides off. The dealer can only replace the whole switch, the switch says Nissan on it so i tried them and they didn't have it. Also checked 2 electronics stores...any place online???? its really not a big deal it just looks better with all the lights working. Quote Link to comment Share on other sites More sharing options...
Commuter Posted February 7, 2005 Share Posted February 7, 2005 I'm not sure if your Impreza switch is the same as the Legacys, but... Do a search for "Climate Control Backlight" thread. Tons of info. Commuter Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 7, 2005 Share Posted February 7, 2005 Check out Newark Electronics, they may have what you need. Here is a link to one of there items that may fit your needs. http://www.spctechnology.com/prodinfo/specs/TA-259.pdf Another thing you could do is replace the bulb with an LED and resistor. You will never have to replace it again under normal conditions. Quote Link to comment Share on other sites More sharing options...
