driving around with a welded diff
the sucker king
not really an issue the rear axles are totally differant than the front. and the rear bearing is just as sealed without the axle as with the axle. before you put the axle on you might want to wipe the dust off of the stub splines and put a light lube from time to time when you put the axle back on. that way you keep it an easy job.
Me too!
I've been looking for some kind of rubber cap to stick on the splines and cover the whole area and keep the dust out of the splines and the bearings. Something like a spray paint can lid made out of rubber or thick plastic may work?
So far I have not found anything that will work.
