oil pressure gauge no workee...
4 replies to this topic
#1 Del Gue
Del Gue
    USMB Regular
  • PipPipPip
  • 44 posts
  • Tulsa
Posted 14 July 2005 - 08:17 PM
My oil pressure gauge has not worked for several months (83' GL wagon). I installed a new sending unit this past weekend (from AutoZone), but nothing happened. The new unit didn't much look like the old blue one that was on the pump. I checked fuses and they are good. Any suggestions? Thanks for the help. I don't like being without me gauge.
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 15 July 2005 - 01:13 AM
I would check to see if you are getting any voltage to the sensor using a meter. You may also be able to ground the lead to see if that does anything on the meter. The problem may be the wiring to the sensor or the gauge itself.
#3 SakoTGrimes
SakoTGrimes
    Aint got no Subaru!
  • 943 posts
  • Grants Pass
Posted 15 July 2005 - 03:34 AM
Get a new one from eBay. I got a 0-100psi one for like $17 shipped. I'll get around to putting it in one of these years
#4 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 15 July 2005 - 08:18 AM
my guess is they sold you an
oil pressure switch
not an
oil pressure sender unit
sender unit should have been about 30 bucks
switch less than ten GWs
by chance does the gage rise when the engine
is not running but the ignition is in the run position?
if so then the above is the case
#5 muellerdeal
muellerdeal
    USMB Regular
  • PipPipPip
  • 52 posts
  • port lavaca
Posted 15 July 2005 - 01:21 PM
i didnt think oil guages worked from the factory on subarus
