simbey1982 Posted July 23, 2005 Share Posted July 23, 2005 Well yet another conversion of my subaru....well mostly impreza....ive got a lead on the stuff for a front disc conversion to turbo leg. From what i see the rotor is about an inch bigger in diameter...is there also more pad surface??? would this create noticably better brake response and stopping speed?? anyone done this?? let me know Cory Quote Link to comment Share on other sites More sharing options...
Setright Posted July 24, 2005 Share Posted July 24, 2005 It may not be worth it, unless you have upped the engine power considerably. I run standard size grooved discs with Mintex M1144 brake pads. They stop the car very quickly indeed, and have stood up to trackday use. What size are your present brakes? Impreza's came with 260mm and either single pot caliper (like mine) or dual pot. Some lucky owners have two pots and 277mm discs. If you really want to upgrade your brakes, replacing the single pot with the dual pot is quite easy. No adapters needed. Better feel and response are the benefits. Fitting bigger discs will mean new caliper or at least a caliper adapter. Also, make sure the wheels will clear the caliper! And yes, the 277mm discs have a bigger swept area. Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted July 26, 2005 Author Share Posted July 26, 2005 Well i have the smaller discs....and probabally the single pot calipers. I can get the calipers with the rotors as well as the back plates....anything else i may need..?? I think they will fit in my 15's but will check...thanks for the info Quote Link to comment Share on other sites More sharing options...
reddevil Posted July 26, 2005 Share Posted July 26, 2005 I hope your weren't going to get the turbo legacy brakes from Foster Road U-Pull-it, cause I got em! I also got the motor and heads, plus the turbo and manifold! All for $189! Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted July 26, 2005 Author Share Posted July 26, 2005 haah nope...what a score......you gonna supercharge it??? btw i had the turbo leg at WCSS7, i bought a DVD from you, tall guy, howz the legacy doing? Quote Link to comment Share on other sites More sharing options...
reddevil Posted July 26, 2005 Share Posted July 26, 2005 Legacy is going great still (all one month!) Not sure what I am going to do with it yet. I am going to sell off all the parts but the block (keeping the brakes of course). Quote Link to comment Share on other sites More sharing options...
