vintagejoe Posted July 29, 2005 Share Posted July 29, 2005 I've been told by a mechanic that it is a 2.5 Another one said it's definately a 2.2 Which is it? Is there a place on the car where it's notated? Quote Link to comment Share on other sites More sharing options...
99obw Posted July 29, 2005 Share Posted July 29, 2005 98 Legacy L is definately a 2.2, last year of the 2.2 in the Legacy was '99. IIRC if you look down at the block between the alternator and the power steering pump it should say EJ22 rather than EJ25. Quote Link to comment Share on other sites More sharing options...
ejlain Posted July 29, 2005 Share Posted July 29, 2005 I've been told by a mechanic that it is a 2.5 Another one said it's definately a 2.2Which is it? Is there a place on the car where it's notated? Hi Joe, Definitely a 2.2L which, btw, as most people on this board will probably tell you, is a more reliable engine. I have the same car. - Ed Quote Link to comment Share on other sites More sharing options...
Drakien Posted April 11, 2009 Share Posted April 11, 2009 Yeah usually with the 97, 98, 99's they have a logo on the trunk that say 2.5GT if it is the 2.5 Yours is a 2.2, if you look at the vin plate under the hood on the driver side of the engine bay by the strut mount, it should say EJ22 or EJ25 on it. I would suggest the 2.2 also, I actually had the 2.5 and am downgrading to the 2.2 for not only better reliability but for gas mileage also. Quote Link to comment Share on other sites More sharing options...
etc Posted April 12, 2009 Share Posted April 12, 2009 I have the same 98 Legacy L, and mine has 2.2L. I also had 1.8L in Loyale and and a 2.5L in a newer OBW. 2.2L is nearly as nice as 2.5L power wise but without the problems. Supposedly 2.2L will last a long time. Quote Link to comment Share on other sites More sharing options...
jmorton822 Posted April 12, 2009 Share Posted April 12, 2009 It would only be a 2.5 if it was a GT or Outback, unless someone did a swap job. Otherwise, it's a 2.2. Not too much of a noticeable difference in power in my mind. I've had a 96 2.2 wagon and a 98 2.5 sedan. Quote Link to comment Share on other sites More sharing options...
