ABS for Older Soobs?
3 replies to this topic
#1 Tom63050
Tom63050
    Subaru Fanatic!
  • 373 posts
  • St. Louis
Posted 03 September 2005 - 08:02 PM
Does anyone know of a company that markets a generic ABS system to retrofit onto cars that don't have ABS?
If so, has anyone tried this out and what were your results?
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,932 posts
  • Sacramento
Posted 04 September 2005 - 12:19 AM
Never heard of any type of system. Dont know how safe it would be, you would be altering your brake system which might be more dangerous than just having standard brakes.
You'd need to impliment sensors and install computers and such that would be pretty involved.
-Brian
#3 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 04 September 2005 - 01:08 AM
Would be prohibitively expensive if it existed. If you want ABS it will probably have to be all custom. Pump, computer, sensors in front knuckles and rear something, sensor pick-ups (notches) on axles, etc.
I could be wrong about everything though. Maybe extensive swapping/modification of newer-generations parts could do it.
--Ed
#4 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 04 September 2005 - 04:06 AM
Probably wouldn't be terribly difficult for a competent machinist to retrofit Ford RABS into a Soob. It consists of toothed ring and an electronic pickup that sends position data to a small computer, external to the ECM, that controls a small check valve (?). The hard part would be getting the ring installed in the rear diff and adding provisions in the case for the pickup. After that...no problem at all.
