Brake Question
4 replies to this topic
#1 simbey1982
    Subaru Nut
  • 600 posts
  • Portland, OR
Posted 21 September 2005 - 02:13 AM
Hello all,
Havent posted in awhile...too busy with my engine these days =) anyhow i need to know if you can somehow replace the adjuster on your brake calipers?? My drivers side pad adjuster (the thing that is supposed to slide in and out and adjust with the wear of your pads) is all but frozen on drivers side and causing uneven wear....so can you replace this part or is it a new caliper??
#2 jimscat
    USMB Regular
  • PipPipPip
  • 79 posts
  • Maine
Posted 21 September 2005 - 05:33 AM
I just had the same problem with my 93, I had to drive the bolt bushing out and clean up everything. There is a caliper rebuild kit available through Subaru for around $35 us (my area anyway)
you may want to check out my post on rebuilding them
#3 BigMattyD
    Subaru Fanatic!
  • 405 posts
  • Syracuse, NY
Posted 21 September 2005 - 01:20 PM
Read this thread, at the bottom, I explained how I fixed mine. I would think if you went to your Subaru dealer, you could get a new bushing, but you probably just need to clean it up. Mine had a healthy dose of rust on it, so that it was literally frozen in position, but once I got it out (I had to drive it out with a hammer,) I could lightly sand it and clean the hole in the caliper where it mounts, and even though there is some minor corrosion damage on the bushing, it slides nicely now, with the application of some brake caliper lubricant.
#4 simbey1982
    Subaru Nut
  • 600 posts
  • Portland, OR
Posted 21 September 2005 - 07:10 PM
Can you order the boots to the pin without buying a rebuild kit??just need those boots...
#5 simbey1982
    Subaru Nut
  • 600 posts
  • Portland, OR
Posted 22 September 2005 - 06:02 PM
looking for a reeply
