Transmissions
9 replies to this topic
#1 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 11 February 2006 - 02:04 PM
Will 5-spd d/r trans from a 4wd carbed 86 GL work for a 89 AWD turbo model?
#2 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 11 February 2006 - 02:21 PM
It will work, but your rear end ratio is different. The turbo trans and differential have a 3.7:1 ratio and the non-turbo is 3.9:1. You would need to change the rear differential to match.
#3 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 11 February 2006 - 03:15 PM
Do the axle splines match up ?
#4 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 11 February 2006 - 03:22 PM
Sorry, I forgot to mention that. The splines are different, so you need those from the donor car as well.
#5 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 11 February 2006 - 03:33 PM
What else will I need?
#6 Subarian
Subarian
    1000+ Super USER!
  • 1,150 posts
  • Orem
Posted 11 February 2006 - 03:40 PM
OK, I hope someone checks me on this, but here's what you should need:
The splines on the input shaft are different, so you'll need a clutch disk from a non-turbo car.
You'll need the complete shift linkage for the d/r and the trim panel for the shifter. It has the hole for the d/r shifter.
You'll need the axle shafts and a rear end with the same gear ratio.
The bellhousing, starter, flywheel, transmission crossmember, and driveshaft are the same, so yours are OK.
Sorry about the omissions in the earlier post. I forgot you were going from non-turbo to turbo.
#7 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 11 February 2006 - 03:45 PM
Ok thanks for the help.
#8 Free Range
Free Range
    Chicken or the egg, hmm?
  • 215 posts
  • Missoula, MT
Posted 11 February 2006 - 04:13 PM
keep the best clutch assy, they interchange on those cars, front axles and rear diff will need to match trans, rear axles stay, any d/r shifter from those years will work. I reccomend driving nice when in 2wd, compared to awd the stress will be all on those front axles. 3.90 d/r's me like, swapped them into four cars now, tractor gears compared to the 3.70's
#9 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 February 2006 - 10:33 AM
Additional note:
The starter is not always the say between EA82 manuals and autos. it bolts up the same, but some of the autos used a long bodied starter that, when used on a manual, tends to get in the way.
#10 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,098 posts
  • East Coast
Posted 12 February 2006 - 12:41 PM
i know nothing of the EA82 starters, but the auto and manuals will not interchange on the XT6 probably for the same reasons you just mentioned can sometimes be an issue on EA82's.
