1ABAJA Posted October 27, 2003 Share Posted October 27, 2003 Would I have to swap computers If I replaced my EJ1.8 with an EJ2.2? Thinking of pimping out this Impreza, but first it needs some serious jeuvos! Josh! Quote Link to comment Share on other sites More sharing options...
slideways Posted October 27, 2003 Share Posted October 27, 2003 Don't quote me on it, but I imagine so. If you want to build a serious car out of it, may I suggest going with a EJ22T or a JDM EJ20T. The initial outlay will be greator, but making HP will be cheaper in the long run. The EJ22T is possibly the most solid base to start from, with a closed deck block and a bottom end good to about 350 hp. A turbo an a few other goodies would get you there. Probably the most economical route would be with the EJ20T. 280hp is easily reachable on the stock turbo. By my calculations, I could do it in my Legacy for less than $2500. Such an undertaking is not for the meek, though. Major supporting components such as fuel pump, clutch, crossmember, computer, possibly radiator, and of course, the addition of an intercooler need to be considered. If I had the dough, I would do it in a second. But school comes first.:boohoo: Also, since I value my life, congruent upgrades to the suspension and brakes would be in order. Quote Link to comment Share on other sites More sharing options...
1ABAJA Posted October 27, 2003 Author Share Posted October 27, 2003 I would love to to put a turbo yupinit, but all I have laying around is a straight 2.2. I recently acquired a baby three months ago...that sucker is not cheap...but I am still going to keep him. So, with that in mind, I need to go the cheapest route possible...so I figure 2.2 with air and exhaust mods. Josh! Quote Link to comment Share on other sites More sharing options...
ccrinc Posted October 27, 2003 Share Posted October 27, 2003 The EJ22 is a direct bolt-in swap for an EJ18 engine. You don't need to change anything, including the ECU. The engines are identical except for the bore. Emily http://www.ccrengines.com Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 28, 2003 Share Posted October 28, 2003 wee- hee! that's what i thought! go for it, Yosh! Quote Link to comment Share on other sites More sharing options...
1ABAJA Posted October 28, 2003 Author Share Posted October 28, 2003 Hey Emily, long time no speak! That is what I needed to know. I will probably leave it in the Legacy for now and pull the radiator out of the Impreza so I have a 4WD for snow season:brow: ....then when the snow melts, I will put the EJ2.2 and the radiator back in the Impreza!....I am going to blow away the RX:banana: !!!! Look out Myoss Feece! Josh! Quote Link to comment Share on other sites More sharing options...
