Tranny Cooler
7 replies to this topic
#1 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 11 July 2006 - 08:16 PM
Did Auto 85 GL Wagons Come With Them Or is This After Market, OR Is It Even A Tranny Cooler? I Followed The Hose But Couldn't See Where They Led.... :confused:
Posted Image
#2 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 11 July 2006 - 09:04 PM
Defintely not stock. I don't think any subarus have come with auxillary tranny coolers (except the crappy ones in the radiators) or auxillary oil coolers.
It could be either tranny or oil cooler. Follow the lines. If its an oil cooler, it'd end up at the fuel filter. If they travel to up where the stock lines are, its a tranny cooler. BTW, stock radiators for automatics have coolers in the radiator. Check the driver's side of the radiator's end tank. There should be hoses there for the tranny.
#3 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 11 July 2006 - 09:27 PM
My Radiator has no hook ups for Trans Cooler And I Followed It Back And I Found Out It Was A Trans Cooler So Is This The Wrong Radiator For My Car?
Posted Image
Oh Well? I Guess It's Better To Have A Newer Radiator And An After Market Trans Cooler :D
#4 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 11 July 2006 - 09:30 PM
"wrong" radiator if you didn't have an aftermarket tranny cooler. Since you do, that one will do you just fine!
#5 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 11 July 2006 - 09:35 PM
i added a tranny cooler to my 88 a/t turbo wagon + new 2 row radiator , temp gauge 1/4 way up , on a real hot day with ac on it might go up to 1/2 up :)
#6 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 11 July 2006 - 09:39 PM
I Wish Mine Would Read That Low Mine Is Usually Always At 3/4 When Warmed Up On A Hot Day. And I Dont Even Have AC :eek: But Never Hits Close To Red So It Works.
#7 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 11 July 2006 - 09:41 PM
3/4 on the gauge is too hot. Flush the cooling system, replace the thermostat and radiator cap. If it still over heats, a change of radiator may be in store.
#8 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 11 July 2006 - 10:30 PM
Hmmm It's Been Ran That Hot For A While With No Ill Effect Yet But I Guess I'll Get A T-Stat And Rad Cap
