Everything posted by ()__1337_CRAYOLA__()>
i dont know what this could be i bought a used wrx 2 weeks ago i have 650 miles of ownership and it uses 1 quart per 200-220 miles and i dont abuse it at all 2,500 - 4,500 shifts premium gas. i pulled the TMIC to see if im getting oil out the turbo but there was just a very light film in the TMIC. exhaust isnt spitting raw oil out and it runs and idles smooth with no missing im at a loss. i changed the oil when i got it for penzoil 10w30 just the basic oil could that be a issue? btw it has 111347 miles on it :-\
she is on a roll
i have a 95 imp with a ej18 and i want to put a 2.2 short block with the 1.8 heads to keep EGR and dual port exhaust but what years of 2.2 will work with the 1.8 heads out of curiosity. (I did search but couldn't find any info) Heres my work in progress it has, - Ground control coil overs - WRX wheels - WRX front seats - Tinted windows - HID head lights - Rally armor mud flaps
you want a 32/36 and you can get the on ebay http://cgi.ebay.com/ebaymotors/Subaru-1985-1987-1-8L-OHC-EA82-Weber-Carb-Conversion-_W0QQcmdZViewItemQQfitsZYearQ3a1987Q7cMakeQ3aSubaruQQhashZitem4cf13b5633QQitemZ330464712243QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3112wt_958 or from weber direct http://www.redlineweber.com/html/application_guide/SUBARU.htm or many other places you just have to look around
wanna buy it 700 without engine and trans 73 squareback
Aren't you all proud of me i sold my Honda and bought a real car It only has 132k on it with the EJ18 it's my first AWD soob to, the interior is minty fresh and the body is only a little dinged up with some key marks. a few questions though how hard is it to do a wheel bearing on the driver front and are there any good after-market shifter bushings because the ones in it are shot or should i just go OEM on the bushings?
camber isn't that bad i think i will shorten the extensions a little bit to make it perfect
Wcss12
()__1337_CRAYOLA__()> replied to bratsrus1's topic in Meet n' Greet. Your USMB Welcome Center
is this the one you showed when i was over recently if so that thing is awesome -
Let's see your LIFTED Soob off roader 2010 edition.
()__1337_CRAYOLA__()> replied to ezapar's topic in Off Road
got my lift done and put in at 4 this morning :banana: and i thought Eric was taking those super-lights to the grave with him -
thanks for the info Scott i'll connect the blocks
so does anyone see an issue with this lift? all blocks are 4 inches and strut extensions are 4"
BTW check out my strut extensions thanks to Jerry for the info and materials and my brother for machining them my lift is started
just so i understand if i want to do a 4" lift i need to drop all points being moved 4 inches or am i wrong on that point
