Everything posted by ()__1337_CRAYOLA__()>
Different kind of rust repair.
()__1337_CRAYOLA__()> replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just foam it and lightly bondo it just in case it falls out and call it good -
What will these fit?
()__1337_CRAYOLA__()> replied to opus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks like its 4 on 140 they should really fit any Subaru from the 80's early 90's other than the justy -
im stumped
()__1337_CRAYOLA__()> replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
no worries it picked up a rod knock today time to put in the other engine i have.... -
im stumped
i just replaced valve stem seals and head gaskets i think 5k ago and it started smoking like this after the first thousand -
im stumped
pcv system is clear although there was oil in all of the lines and also does anyone in the Seattle area wanna adjust my hydro lifter setup after redoing the head gaskets they've been loud but i don't understand how to adjust em hah... -
im stumped
hahaha i know its bad but it's all i could get why would the pcv hose clogged put oil in the cylinder? -
im stumped
i can park it anywhere and it will do it if it sits for an extended amount of time i replaced the pcv with a fram which is probably a no no but its only getting oil in the number 2 hole -
what would cause number 2 cylinder to fill with oil over night not a lot but just enough to make it smoke for a mile and the plug is oil fouled as well. all other holes are clean and spark plugs are the color the should be.... compression is 125 for all 4 holes I'm stumped my brother says valve guides but i dunno plus, if you pull it up over 4k it smokes like a chimney to oh its a ea81 with FI swap if it matters
My neighbors house caught on fire and almost caught our trees on fire as well as having his ammunition going off for 4 or 5 minutes straight fire trucks surrounding my house was kinda cool but the whole burnt wet cedar smell sucks as well as the neighbors losing there house no one was hurt tho
Throttlebody Help
()__1337_CRAYOLA__()> replied to Southwestmale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like fuel pump problem can you hear the pump running? -
Wagon running poorly...
()__1337_CRAYOLA__()> replied to MysteriousXTC's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i had this problem on my turbo wagon it was caused by bad iridium spark plugs i put a standard set of NGK's in and everything was fine -
Would like some tips
()__1337_CRAYOLA__()> replied to dasuchbe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and for the timing belts you can mess em up all you want its non interferance -
Slammed hatch
()__1337_CRAYOLA__()> replied to ThirdEyeHatch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
he used eg Honda front struts with adjustable coil overs and re-clocked the rear torsion bar -
Gen one A bar on gen 2 car?
()__1337_CRAYOLA__()> replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can i get the a bar :-P -
2" Lift kits for EA82?
()__1337_CRAYOLA__()> replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the shaft that connects the steering wheel to the box in between the u-joints has to be extended it isn't hard lift the rig cut the shaft in half find appropriate tubing and weld it together (tac it together in car weld on bench) -
Rockin New Kicks
yeah i bought this one as a daily cause it was fairly rust free... the brat was rotting away so i got rid of it befor it started to fall apart
