transfer solenoid
1 reply to this topic
#1 patcal
    USMB Regular
  • PipPipPip
  • 91 posts
  • Portland, OR.
Posted 10 November 2003 - 03:24 PM
OK. Last questions. My duty solenoid is bad. After I get the extension housing off, can I change the solenoid without anymore dis-assembly? Do I have to remove the clutch pack to get the solenoid out? Thanks.
#2 dashton
    USMB Regular
  • PipPipPip
  • 43 posts
  • Springville, Utah
Posted 11 November 2003 - 01:51 PM
Yes, once you get the extension housing off the solenoid is right in the bottom of the housing. You don't have to remove the clutch pack - but if you do it's a piece of cake to take it apart and check the disks. Just make sure you put it back together in the same order. The only thing to watch out for is when you pull the extension housing off the transmission there are a couple of pieces that like to fall out. They are the parking brake locking arm and spring. Just be careful and watch where they go so you can get it back together. I have a couple of pictures of the extension housing removed where you can see the solenoid, but I don't know how to post them. You can e-mail me and I'll reply with them attached. Good luck! dashton@wencor.com
