Intake manifold bolts... yeah...
9 replies to this topic
#1 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 16 March 2007 - 09:02 PM
So I just extended my 79's timeframe by quite a bit...
... the four remaining intake manifold bolts all broke off, the ones toward the inside by the coolant passages.
I didn't use any, but no amount of PB Blaster would have helped. The bolts started to "turn" quite easily, and then just snapped off.
If I feel adventurous tomorrow, I might grind into them a bit and try unscrewing them with a flathead screwdriver. But most likely I'm just gonna pull the heads and take them off to a machine shop.
Besides, a slight bit of coolant spilled into the intake ports when I cracked the gasket, so I should probably pull them anyway.
Good thing I'm not in a hurry. :rolleyes:
Subaru, why did you have the coolant pass through the intake manifold before entering the engine? Why???
#2 moosens
moosens
    Vintage Subathusiast
  • 1,835 posts
  • Bridgeport CT
Posted 16 March 2007 - 10:23 PM
Drain the heads from underneath.
If I understood right,you've removed,or started to remove the intake...?
#3 moosens
moosens
  • 1,835 posts
  • Bridgeport CT
Posted 16 March 2007 - 10:25 PM
Coolant can be sopped up with a lintfree rag mostly,and the rest just blow out when you start it.Not the first guy this happened to.No biggie.
#4 DerFahrer
DerFahrer
  • 2,420 posts
  • Orlando, FL
Posted 16 March 2007 - 10:40 PM
Yeah, so how do I drain the heads from underneath? :confused:
I was expecting to find drain plugs in the block like the newer Soobs (even the EA82s have them), but they're not there.
Intake manifold is off. I have the carb intact with all its self-contained vacuum hoses still mounted on the manifold.
I'm concerned about the coolant making its way through an open valve and getting into the cylinder and sitting there.
#5 moosens
moosens
  • 1,835 posts
  • Bridgeport CT
Posted 16 March 2007 - 10:52 PM
That'll blow out,don't worry.
Passenger side head should have the drain plug.As I recall,it was always the passenger side....correct me if I'm wrong,please.Quick look at an FPM shows it.
Posted Image
Part #32 above.
#6 DerFahrer
DerFahrer
  • 2,420 posts
  • Orlando, FL
Posted 16 March 2007 - 11:08 PM
Aha! So that's what that was. I wasn't sure, so I didn't touch it.
Thanks Paul! Good to know for the future.
#7 moosens
moosens
  • 1,835 posts
  • Bridgeport CT
Posted 16 March 2007 - 11:26 PM
Rock 'n roll my brother!!:headbang:
#8 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,260 posts
  • East Coast
Posted 17 March 2007 - 12:42 AM
those intake bolts do suck real bad. while pulling the head isn't necessary, if it were going in a car i planned on driving i would replace the headgaskets probably. unless i knew something about the engine and was confident it was in great condition.
i've posted a number of very in depth times about tricks on getting the intake bolts out. and i know it doesn't matter now since yo'ure done, but if you care in the future: soaking in a penetrant can help, even more so with some other tricks. first one is to loosen a little, then retighten, loosen a little, retigthen. keep doing it to help loosen them up. if you can get the bolt up at all, get a pry bar underneath the head and pry up while turning. these two tricks help very much.
#9 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 17 March 2007 - 11:51 AM
I have used helicoils on many gen 1 heads before. I just made sure to put a punch mark right in the center of the old bolt before I started to drill. Then just retap, insert coil and voila. You can also use the intake as a guide if need be to drill out the old bolt before stepping up to the larger bit that the helicoil uses.
#10 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 18 March 2007 - 01:08 AM
When this happened on my turbowagon, I replaced those bolts with stainless steel :-P And if the bolt broke off above the surface of the head, they have these nifty deals at Sears that you drive over the end with a hammer and then twist it out with a socket. Works on rounded off bold heads too!
