3AT weird noise?
6 replies to this topic
#1 misledxcracker
misledxcracker
    Guy no one ever answers
  • 846 posts
  • Bullhead City
Posted 13 September 2007 - 02:16 PM
'86 SPFI with a 3AT.
Has governor issues, when warmed up it shifts fine, but makes a soft, whining type noise throughout all the gears (really low noise, radio covers it up) This occurs when cold or warm, it makes no difference.
I did a drain and fill around 4K ago, and the pan was full of black sludge, but no metal particles. Filter was nasty, but also did not have any metal particles.
Fluid level is OK, I'm going to check it again just for S&G here in a second....
BTW: I've noticed a LOT of cars make this same weird noise, Fords, Hondas, etc. It's just that... I don't want mine making noise at all :lol:
What could it be? Front pump? Governor? Blinker fluid? :lol:
#2 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 13 September 2007 - 02:33 PM
Okay, so I just pulled the vacuum modulator line.... and out came ATF :dead: :dead:
But I didnt lose any fluid; yet all of my vacuum lines have ATF (I think) inside of them...
I JUST replaced the modulator, too! What the...
***EDIT***
The car never smoked, and never seemed to lose fluid since I did the flush. So....
I ran the car with the vacuum hose coming from the modulator off, got all the gunk out of the vacuum line, put it back on, and took her for a spin about half a mile or so. Now when I disconnect the hose, nothing comes out.
Maybe it was just old fluid from before that got stuck down there? Does that sound about right?
Either way, looks like the modulator is fine, and the car doesnt shake at idle nearly as bad as it did before...
Not to mention the noise kinda subsided!
#3 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 13 September 2007 - 06:38 PM
is there any chance that you are hearing gearbox chatter from the differential unit??
Thats about all I can come up with....
#4 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 13 September 2007 - 08:04 PM
Sometimes you need to go out and buy that 500 watt power amp to fix the noise.
You may just be hearings the gears meshing. If the car is shifting fine, noise levle fairly constant, I wouldnt worry about it.
You may just want to change the fluid.
nipper
#5 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 14 September 2007 - 11:41 AM
Something's telling me the oil in the vacuum lines was not ATF, but engine oil.
So I cleaned out the PCV system... got LOADS of hard black stuff out of the PCV lines. :dead:
If the PCV is crappy, can that happen? (Oil in the intake)
#6 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 14 September 2007 - 11:58 AM
Yes. Replace the pcv valve
nipper
#7 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 14 September 2007 - 12:23 PM
The PCV rattles just fine... but I think it's a cheapie :dead:
Gonna get a dealer PCV asap.
