Changing serpentine belts
5 replies to this topic
#1 bishop087
bishop087
    New User
  • PipPip
  • 16 posts
  • Newburgh, NY
Posted 26 January 2008 - 10:26 AM
Hi All-
I was just wondering if there is a post around on how to change these damn squeaky belts in my '99 Outback Impreza wagon. It doesn't look all that hard, I just don't want to miss any small step that might make or break the job.:confused:
Thanks in advance!
#2 Bigbusa
Bigbusa
    USMB is life!
  • 256 posts
  • NY
Posted 26 January 2008 - 10:45 AM
I just changed my a/c and alt belts on my 96 2.2L. It was really easy. Crank the alt adjuster down until you can remove the belt, slap the new one on and crank it back up until the belt is tight.
On the a/c belt I removed the 2 bolts holding the roller tensioner on, removed it and the belt came right off. Reverse procedure to install.
I'm guessing you can do this job in a 1/2 hour.
#3 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 26 January 2008 - 10:52 AM
I would just like to add one small but important item.
Loosen the lock nut before cranking the adjuster.
#4 Bigbusa
Bigbusa
    USMB is life!
  • 256 posts
  • NY
Posted 26 January 2008 - 11:27 AM
oh Yeah and the pivot bolt on the alt.
#5 bishop087
bishop087
    New User
  • PipPip
  • 16 posts
  • Newburgh, NY
Posted 26 January 2008 - 04:01 PM
Thanks guys! I just replace the alernator belt. I didn't need to replace the a/c belt yet. The install went easily and flawlessly. Thanks for the help!!!
:headbang:
#6 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 26 January 2008 - 05:29 PM
I hope I speak for the entire board
in saying
you're welcome and glad it helped.
BTW Thanks for saying "thanks"
nice to see the input appreciated.
