help with installing rear seal for a driveshaft
4 replies to this topic
#1 babyfacefitz
babyfacefitz
    USMB Regular
  • 169 posts
  • st. louis
Posted 06 May 2008 - 10:30 AM
With the help of this forum (gary and ben) I have a working driveshaft installed. The male end of the shaft looked good and I slide the seal onto the male end. I figured the seal would slide back to the appropriate placement.
It did not work. I am still getting a lot of ATF coming out. Any suggestions?
This is a 98 OBW with a rear driveshaft replaced.
Michael
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 06 May 2008 - 02:57 PM
Michael
the seal is installed in the a$$ end of the trans. the drive shaft is removed when you do this. you are going to need a larger socket or something to tap it in because it sits around the splined output shaft of the trans. i have'nt done one, but i doubt it's any different than any other seal. slide into place and gently tap it to seat.
calling the front end of the drive shaft the male end is a mis-nomer . it's both male and female. male because it slides into the trans/seal, female because the splined trans shaft slides into it.
#3 screwbaru2
screwbaru2
    Subaru Nut
  • 604 posts
  • hope valley
Posted 06 May 2008 - 03:03 PM
There's a lot of that these days!
#4 Gloyale
Gloyale
    It's a sickness
  • 10,641 posts
  • Corvallis, OR PNW
Posted 06 May 2008 - 08:57 PM
Duh, It's a Tranny seal! LOL
#5 babyfacefitz
babyfacefitz
    USMB Regular
  • 169 posts
  • st. louis
Posted 18 May 2008 - 11:04 AM
Got it put and thanks for the help.
michael
