njdrsubaru Posted June 19, 2008 Share Posted June 19, 2008 does anyone have a diagram? i am doing a special project and i need that diagram. Yes its for the switch on top of the steering column thanks in advance Quote Link to comment Share on other sites More sharing options...
OB99W Posted June 19, 2008 Share Posted June 19, 2008 does anyone have a diagram? i am doing a special project and i need that diagram. Yes its for the switch on top of the steering column[...]First I want to know if it involves turning fuel injectors on/off. Quote Link to comment Share on other sites More sharing options...
njdrsubaru Posted June 19, 2008 Author Share Posted June 19, 2008 no it doesnt :brow: i am mounting a pair of hellas and i want to disconnect that switch and wire it to turn my fogs on and off Quote Link to comment Share on other sites More sharing options...
aircraft engineer Posted June 19, 2008 Share Posted June 19, 2008 remember - use it to drive a RELAY or you will overload the wires. Quote Link to comment Share on other sites More sharing options...
OB99W Posted June 19, 2008 Share Posted June 19, 2008 [...]i am mounting a pair of hellas and i want to disconnect that switch and wire it to turn my fogs on and off Hopefully, the attached partial diagram covers your model, and will do the trick. Please verify it agrees with your car before rewiring. Also, be certain not to exceed the current limitations of the switch or its wiring; if there's any question, a relay may be needed. (EDIT: I see while I was preparing the diagram for uploading, aircraft engineer already made the point about the relay.) Diagram notes: Fuse #23 is hot all the time. The red/blk wire at the bottom of the diagram (not to be confused with the blk/red one) goes to a 10 amp fuse labeled #5, the other end of which feeds the front and tail (parking) lights. Quote Link to comment Share on other sites More sharing options...
