Code was 34 (EGR solenoid/valve or circuit)... thanks for the above info on that...
OK, I did a search and found out WHAT an EGR is, now I am still looking for the solenoid (my probable problem) which I understand is on the intake, Pax side near firewall? Anyway, will pull it (when I find it) and try cleaning it and testing the contacts. After reinstalling it or one that works, I have a question...
How do you reset the 'check engine light"? I read where you are suppose to connect the "self-diagnostic connectors and the read memory connectors" But where do you connect them to? They are ALL female plugs???
Thanks...
Doug
PS by "flashing" I meant the "Check engine light" would slowly light up and then go out and then slowly light up again with about a 2-5 min, no light at all until it finally came on aout a month ago and now stays on...
I don't think it is the resettable switch I read about that comes on at 60K (mine was maybe? reset when I had the new timing belt and water pump installed...)?
