jaacina
  1. The guy selling them measured them and said that they are 5.5" across the hub. That sounds like it would fit. I wish I knew if some else has used them.
  2. I had a question, I searched, but all of the posts I came across only mentioned the 504 and 505 Puegeots. Does the 604 share the same wheel bolt pattern? Is the back spacing ok with these and an EA82?
  3. which plugs? The ECU end or the engine end?
  4. Well that would probably solve all issues. Cool.
  5. I see that now that the ECUs are different. Can I use an '88 wiring harness and ECU on to an 9/86 motor? Are those connection different?
  6. Will a wiring harness from an 87.5 or newer EA82T fit onto a 7/86 EA82T engine? How about the 6/86 ECU working with the 87.5 and newer wiring harness?
  7. I have a large Samoyed who in the past has gotten destructive like this. He only did it during thunderstorms. I learned quickly not to leave him unattended during storms. I put him in his crate so no longer damaged anything nor hurt himself. No idea what happened to him in his past that caused such a problem with storms. If the dog is left unattended and just tied up outside I am sure it gets bored just like you and I would. A dog should not be kept like that.
  8. So you put a non turbo engine?
  9. Have you done your Loyale yet? I have a '92 that I recently purchased with high miles. I was going to convert to 5 speed. Picked up a dual range to put into it. Then I came across an '87 XT with a 1500 mile rebuilt engine in it for $50. So I am going to swap the XTs turbo engine in the Loyale. How much work is it to modify the XT's harness into the Loyale's? Is that even possible? What is the best harness for me to look for? Will a MFI harness work?
  10. I am looking to do a similar swap... but I would replace my '92 SPFI Loyale with an '87 Turbo MPFI from an XT. I was told that the wiring harness will be nightmare due to the digital dash issue.
  11. I was thinking of using a small lawn mower type mower turning a generator which recharges a battery pack. Then have the battery pack powering an electric motor. http://www.motherearthnews.com/Alternative_Energy/1979_July_August/An_Amazing_75_MPG_Hybrid_Electic_Car Just another option. Batteries and control might get expensive.
  12. Well this 9/86 XT that I bought for $50 has it. Does anyone want it and parts that it controls? The kid I bought it from took the air compressor pump, and the front air springs don't seem to hold air. There is another set in the trunk. Also looks like a set of rear air shocks. The rear on the car has springs. I am going to take the engine out and few other drivetrain parts... wish it had an LSD... and junking the rest.
  13. I think I will do the XT6 5 bolt conversion instead. I have a bunch of 6 bolt wheels from my Land Cruisers, but I think it will be ok with that pattern.
  14. Do you think the wiring harness that is in the XT I have will work fine? Should I worry about the fact that the XT has a digital dash and the Loyale does not? Also, how common is it to have an XT with a button on the bottom left that is for height?
  15. My Loyale is a SPFI. So the next thing I suppose I need to do is get a FSM for both a 9/86 XT and '92 Loyale so I can figure out the wiring harness differences. Anyone have the service manual with wiring harness diagrams for this years/models?
