rverdoold
    2
Posts posted by rverdoold
  1. Ok back from few days not at home.
    Yep live here in holland in a very wet and moist environment, about 100 miles from the coastline though safely 25 meters above (current) sea level:lol: .
    Anyway its so moist that if i dont use the car for a week it will not start trouble free, just moist no CEL though just runs very rough but after 2 to 4 minutes it will be fine.
    No need to impress girlfriends parents, (renting a car is just way over budget 1000 euros for 2 weeks) was there in summer with same car. The winters there are very dry and cold. Actually you can dry cloths outside there, the water will evaporate because the humidity is even lower.
    I got some stuff:
    • 4 snow tires (Well 1 season used last year, had them already, its obligatory to use in Germany)
    • Battery
    • jumpstarter cables :grin:
    • Coolant was to -20F (still doubting about that, can take some out and add some pure stuff, it will mix itself)
    • 5-30w oil + new filter (changed 8k km ago)
    • washer fluid is taken care of with IPA (iso propyl alcohol)
    • have a air compressor in the car so can inflate tires up to 20 bar:eek: (not that i wanted to)
    • Locks are cleaned and fine
    Since i use this car daily without trouble i dont expect it to give problems, we had some freezing nights already. The only problem i had is the lack of heated seats :mad:
  2. I have driven in cold weather but never with my own car (rented). Now in the mornings its getting colder here (well below 30F), the first 10km the car feels cold and tells it doesnt want to do anything sporty (try to never exceed more than 2500 rmp) It all needs to warm up.
    Washing fluid is taken care of as a biochemist i have plenty of non-freezing safe chemicals like ethanol 100%.
    What is it with the drygas?? maybe i know it under a different name but for now it doesnt ring a bell to me.
  3. I am planning to have Christmass this year at my Girlfriends family in the wonderful Baltic country of Latvia. There will be some issues driving there in the winter. First problem driving on snowy roads is the lack of AWD in my '91 Legacy, but if you drive normally with snow tires and chains there is no problem. Things which interest me more are:
    Coolant (night temperatures can go below -22F)
    Oil, driving during day temps will be from 5 to -10F are there special oils i need for the engine.
    Battery, think when it gets cold just take it out during the nights, problem this will clear ECU and TCU is this a problem to do it daily?
    Any other things i should take care of?
  4. When i read the http://www.bobistheoilguy.com/ i wanted the Schaeffer oil but no way to get it here in Europe.
    I changed oil to 'Kroon Olie' (a proper dutch brand) half synthetic and it stopped the leaking at the filler cap. Engine runs nice and gets to temperature smooth.
    On http://verifier.rust.biz/oil.htm are also some hints and tips. On the bottom there is this oil chart. stating you should always get at least (:confused: for the sentence) API SH.
    Think good oil filter is also very important. Problem again is that i dunno those brands like Fram and purolator, never seen them here. If i get the original from the dealer/stealer it costs me 14 euros (about $$22, uhmm well exhange rate is bit bad)
  5. When i replaced the oil i figured out it was overfilled a little bit (really not too much but more than it should be) and i remembered that the clutch pack was never engaged (i check this by driving 80km/h giving little extra throttle if the rpm increases immediately a little bit than its still driven in viscous coupling if it doesnt increase much (lets say 50 rpm more instead of 200 with viscous coupling) its locked up.
    When i changed oil to the proper volume it worked better. but i guess it has not much to do with the brake bands. I also read that the lock-up works in 2 3 and 4th but until now i have only seen it happening in 4th.
  6. could be driver error.
    But occasionally during a downshift from 3rd to 2nd with a speed of 70 to 80 km/h it also goes to neutral mode. Putting it back to 3rd or D gives Drive back. Strange thing is that during a flatout i can hit 110 km/h in 2nd so 70 to 80 should not be a problem. In the mountains driving down the mountain it is usually never a problem but sometimes it gets hard on the brakes when it is forced into Neutral.
  7. Found some strange behaviour in my automatic today (91' legacy 2.0 fwd)
    What happened:
    Car in front of me blown its rear tire and stopped without to many damage. I had to reverse quick to prevent getting hit by oncomming traffic manouvering onto my lane (i was stopped alread). Then while reversed on the wrong lane i had to be in my lane ASAP so stopped quick and front wheels locked up (meanwhile i put gear in N). Moved shifter to 3rd (just quick pushing it down passing D whas not really interested in looking at the gear shifter). Drove quickly away to my lane and slowed down. Now the moved shifter to D and there was no drive, back to 3rd and drive was engaged. Stopped and checked people in blown tire care, all ok. Put shifter in D and everything was fine (all gears normal shifting, no errors).
    Any reason why drive was lost in D???
    (speeds were low but little abrubt changing them from forward to reverse to forward)
  8. I vaguely recall someone saying that Subaru put in ATF indicator lights starting a certain year, but I'm not 100% sure. My '93 doesn't appear to have one (or it's burnt out :dead:), but I wanted to check with the experts first. Thanks!
    I was thinking the same with my FWD '91 legacy. The 4EAT works fine (after rebuild) but the light doesnt come on at start sequence.
    I did some searching. FWD automatics do not have the light (also in dutch manual) AWD automatics have.
    So FWD no light (i checked mine and actually there was not even a bulb present)
  9. Found that the best way to measure on automatic is with warmed up (15 km drive).
    1. Remove dipstick and whipe it off (and take it in the car or just dont lose it, but dont put it back).
    2. Go in car and go through all gears and in D and R let the car actually move a meter or 2.
    3. Put it in park and get out. Leave engine running.
    4. Get dipstick and cool it down in windscreen washer container for a minute or so, whipe it.
    5. Stick it back in the tube and pull out, And read out.
    If there is too much take a big 50 or 100 ml syringe with a teflon tube which fits in the dipstick tube. Let it cool down and insert the teflon tube and remove the oil with the syringe.
    Success
  10. Here overseas we dont have the baja (officially, very few imports) neither the outback sport. How should i see the baja? An legacy outback station with the last part removed converted into a pick-up (el camino style). Or are there very different things besides its the previous model legacy based car. To me it looks like the overhang on the rear is bit larger, what about the wheelbase. Its such a cool car.
  11. For the difference in circumference its not so much
    205/55/16 = 78.2 inch (811 rev per mile)
    195/60/16 = 79.2 inch (800 rev per mile)
    this is a 1.3% difference which can be tolerated
    Better would be to take 185/60/16 because they are little smaller (77.7 inch) so they will definitly fit.
    Or you can play yourself at
    http://www.miata.net/garage/tirecalc.html
    But they both will fit (195 and the 185) actually winter is comming so smaller tire is more weight per ground area = more grip on slippery surface.
  12. I am not convinced Hydrogen or electric are an answer. Maybe there, here the electric industry is the dirtiest industry in N America, be it acid rain from coal burning plants, or nuclear waste to be disposed of, the electricity generating industry creates more pollution than the top two other industries. I *think* it more important to utilize the resources as best as you can, rather then hope for a major change that will take decades, not years.
    Everybodies says 'Reneable Energy' and i can not disagree with them but. The way it should be donei not that easy. Here the just opened an Off-shore windgenerator plant. Since we have lots of Natural Gas recourse our energy is made from that which is not the most polluting from the choices. The previous government said that by 2012 all our nuclear power plants would have been shut down but new one says at least untill 2025 they are open. At my university they designed a tidal energy station and the trails look very promising. But you are right it took 100 years to get here and it needs also time to go further.
  13. you will only be doing it because its better for the environment.
    Reality check:
    Propane is an oil by-product from the manufacture of gasoline.
    You would be doing far more for the enviroment to purchase a vehicle that is the most fuel efficient, no matter the fuel, from the beginning, not the end.
    Yes you are right, but here in holland LPG is usually just flamed at the refinery. So the product is waste of making gasoline. So in fact its cleaner to run on waste than on gasoline :eek::confused: .
    I completely agree on the fact that we should change to an other source of energy. Biodiesel is an option (and really hoping the new boxer diesel will run on biodiesel). Than is the E85 (ethanol85) a real option but yet no information from subaru europe about both of these topics. The question if the diesel could run 50/50 on diesel/biodiesel was a very euuuhmm we are not sure yet answer. If subaru wants to sell the diesel in germany (most diesel country in EU) it has to be able to run biodiesel.
    Of course biodiesel and E85 are steps in between to Hydrogen or pure electric but that will take at least an other 50 years.
    On average an installation + installing + MOT costs 2000 to 2500 euros
    $2845-$3560 US
    Sorry about the dollar euro exhange ratio. But its nice for me to import things from there. (15 years ago it was the other way around)
  14. Well the thing here is a litre of gasoline E95 = 1.50 euro and propane is 0.50 euro (dont convert dollar euro ratio is not to good for americans).
    On average an installation + installing + MOT costs 2000 to 2500 euros, fuel consumption is 8.8 l/100 km for gasoline and 11.1 l/100 km for propane. Here we say we have to drive at least 7500 km a year to be cheaper of with propane. There is more than only a price difference in tanking. Propane cars pay (for 2.5 05 OBW) 800 euros road tax while without propane its 500 euros. This is only because the propane is a modern G3 labeled system otherwise road tax would be 1500 euros which is not good for the switch KM (ratio when propane becomes cheaper).
    With such a small difference in price you will only be doing it because its better for the environment. Plus on an fuel injected engine you need a propane injected system. Its much easier for carbarated cars then.
