Everything posted by subaru girl
headlights
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy lenses are foggy looking and wanted to change them if i found some good ones.
headlights
do the lenses unclip or is it all one piece on a 90 legacy
94 legacy l wagon
subaru girl replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just went to look at one, the body looked perfect but under the front between the bumper and the engine was all rotted out. had the same problem on mine so check for rust. it seems like i see alot of them that are rotted in the rear fender wells to.
trans shifting
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just wanted to check because my other one shifts into first right away. thanks
trans shifting
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90 legacy l 4wd and the fluid was just changed
trans shifting
if i stop and don't wait like 5 sec. it seems like the car starts out in second gear what could cause this
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwent to the soob dealer and got the parts 88 for pump and about 50 for belt. i droped it off at the local garage, it's to cold out for me to do it.
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is now leaking coolant. it's dripping and the bottom of the timing cover is wet. i'm sure it's the water pump thats leaking and making noise. i called the subie garage and they said over $200 labor and $200 for parts. advance auto price is $71 for pump and $29-55 for belt depending on brand. subaru genuine parts is $ 66 for pump and $43 for belt
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif i took the crank pulley and the covers off. could i start the car without the alt. belt on? all i know right now is the noise is coming from the left side and the heat prob just started shortly after the noise started. if i put a breaker bar on the crank bolt and crank the car, where should i put the bar.
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno, only if the defrost button is pressed i had it on vent what area is the water pump located . maybe the noise and this are related
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoolant is full
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi thought the belt was not to old because all the writing on top still looked good (not worn off). the noise is on the left side close to the cam. one more thing but i don't know if it's related or not, the last 2 times i drove it, the car was warmed up and throwing good heat but when i stopped the air got cold until i started going again. but after a while this will stop and it will have good heat.
engine noise
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit sounds like its coming from the left side. i pulled the end cover off and the belt looked good. whats on the left side that could make noise.
engine noise
there is a rattleing/ draging/scraping type sound in the front of the motor. i almost thought it was those covers on the exhaust but it sounds like timing belt area. it has 218,000 on it and i don't know when the belt was changed before.
how many miles does your Ej22 have??
my fwd 90 has a little over 218,000 does not use or leak any oil
trans fluid
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow much will it take to drain and refill.
testing a coolant temp sensor
i have 2 that are out of the car. is their any way to test them to see if they work.
trans fluid
subaru girl replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90 legacy 4wd auto i just wanted to know if the walmart/auto parts store stuff would work or if it is a special stuff from the dealer.
trans fluid
is their a special kind or would any kind work.
Newbie questions (Code + speedo)
subaru girl replied to subjfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think there is a site that has them listed but i don't remember it. if you get a code let me know and i can look in my haynes manual.
subaru girl replied to subjfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtheir are 2 black plugs under the dash. plug them together and turn the key on. the light will flash you the codes. to get to it take the screws out of that panel under the steering wheel above your legs. look around they are there. count the number of flashes long and short.
88 subaru
it doesn't have turbo or thw wing. but other than that it looks about the same except for it being red
88 subaru
i found a pic. it looks like this onehttp://www.ultimatesubaru.org/photos/showphoto.php?photo=6637&sort=1&cat=712&page=1
88 subaru
it has a tach. and it has auto trans with a button for 4wd on the side of the shifter.
