Salty
Posts posted by Salty
  1. Here's a simple fix that works most of the time. Change the oil and filter. Put in a quart of Marvel Mystery Oil. Run the engine at high RPMs. Going down the road at 4000-5000 RPMs for a while will usually get it loosened up.
    It looks like I got lucky. The car had been sitting over 6 months and the noise went away after driving it 5 miles.
  2. I don't know for sure but it may be like my 85 clutch. The clutch fits in a recessed area on the flywheel and can get jammed by dust worn from the clutch disc. It isn't real difficult we just replaced our clutch and the only problem was getting the right parts. We pulled the engine and it seemed easier than trying to pull the tranny and drive shafts.
    This is the easiest engine I've worked on.
  3. I was careful and the oil pump body holder split anyway. It looked as if it had been shellaced in. I was looking at the pieces and the bolt holes in the pump looked like they could be tapped for larger bolts which then could be used as a puller like some GM auto tran pumps are. It's too late for this pump but I will use it if necessary.
    Luckily my donor car came through like a champ with a pump with a lot less wear on it.
  4. I have an oil leak from the area close to the oil pump. I attempted to remove it but after removing all the bolts the pump will not come out. It looks like someone may have epoxyed the oil pump body holder into the block. There is also an allen set screw next to the pressure switch that is not explained in my manual. Does anyone here have a suggestion. Thanks for all the other help I've received from this site
