86ROO
Posts posted by 86ROO
Those will do just fine. How do want to make the transaction?
what are the spacers on the left side of the pic are those for the rear?
Do have pics of the blocks. If they mount on top of the strut I will take them. thank Bill
yes its a ea82. I was planing on droping the the diff 2" so the axles dont bind ,but the im worried that torion bar might break if i dont lower the frt part of the rear suspenion. the other thing i was looking for was the frt strut spacers. I've seen other spacers that dont look like they have the camber offset that is needed i am looking for 0 cmber in frt so the tires dont shave the out side edge.
Does anyone know where I can get just the front strut spacer for a 4" lift kit? I have made most of pieces for my lift but I need the those spacers
to finish the job. if anyone can help I would be greatful
hey I have a question. Im in the middle of building my own lift kit. I have all the parts eccept for spacers for the rear pivot arms by the fuel pump. The lift kit I making is a 4" lift and I was wondow do i make a 4" spacer for the pivot arms or is shorter. If you could help I would be very greatful
thanks
Is there anyone out there that still reworks the ej wiring harness to work in a ea body?
How much and how will it take to do it?
if you can unlock the bulb socket then grab where the wires go in to the socket and twist counterclockwise about 1/4 to 1/2 half a turn and pull it out. then remove the light bulb and revse the procedure
Yes I have a jigshaw. but it isnt very powerful. I was going use it to cut out the wooden template. One of my customer has a big cuting table I am going to have them cut my front strut lift plates for my lift Im making. I will ask if they can cut my spacer plate.
Thanks guys for your quick response on the matter I will try to make one myself the only problem is that all I have is a die grinder to cut with.
I am looking for an ej to ea adapter plate. I have a 86 gl wagon that I want to put the 2.2 in and I the adapter for it. Dose anyone have some making yet? Since allied stop making them. If know one has I found a machine shop in the Vancouver Wa area that will make them for us that want them. If interested let me know. just to let you knowI go out of town a lot for my job but just for one knight I will reply when i get back th next day.
Why dont you use a 1988-90 nissan maxxima alt off the v6. Its 90 amps and depending on the belt you use you need to change the pulley Its internally regulated like the soobies and you can find them in the jy pretty cheap if you get one from the jy make sure to get the plug on the top or side of the alt. and just hook up the small wire on the plug to the small wire on harness and the medium wire to the medium wire. It has the same bolt configuration as the soobies it just has a little larger case so there is no cutting or modification to it I have one on my 86 and it works great have any questions let me know
I have a 86 gl wagon 4x4 that is carbed and I also have a 87 2wdsfi
I am think of put the 87 in the 86 or should I wait and invest in a ej2.2
please help
steve
josh
Do you noice a difference in performance? What size tires are on your car?
are you able to use fifth gear? Also what vin number on the engine has the 135hp if there is one?
Where do I look for threads on this subject?
I have a 86 gl wagon that Im building a 4" lift and I have been reading the threads on ea to ej engine swaps and I was wondering how to alter wiring harrness work in my wagon? I heard of looping the connectors that wont be used. How do you loop, like the speed sensor and the air bag sensors and the others sensors .when I was looking at the legacy I found two harnesses in the engine compartment which one do I need to make this 2.2 run in my car and will it hook directly to in dash harness viva key switch? I forgot to mention that my car is carbed right now.
that would be cool if we could adapt a lsd from another vehicle. I email a company call right-loc they make a clicker posi like the detroits and he said
that I would have to get a lot people to want it designed to keep the cost down for manufactoring and the minium number for the order was 70 units.
Its a cool setup all you have to do is replace the spider gears with the right loc setup , there are no shims or special lubs to use.
Has anyone taken a wrx tranny apart with the posi and try to fit the posi in a d/r tranny
Thanks for the help I will look in this.
I am looking for stiffer and 1/2 to 1" taller springs for my 86 soobie.
anyone know springs from another car that will work?
I'm looking for a thicker wire spring. I looked in moog and federal mogals
spring books but they dont list subaru in there at all. Any advise would help
Hey subie fan hope this helps
Also check the headlight switch it too can be shorting out inside .If it is get hot that means it is melting the circiuts together and shorting out inside
good luck
good luck
Thats the some one I have on my car. Now all you need is the pulley and if you want is the plug in for easier installation and make sure to put either a extra wire the same size as the one on the car so it is duel wires like the maxima or put one bigger wire like 10 or 8 gauge
so it wont overheat and melt while under heavy load. sorry i forgot to you that wire is the main power wire to the alternator. the pulley and the plug can be purchased at any auto electric shop. The plug wires the same way it has a big and small wire coming from it just cut the old plug hook small to small and large to large . hopefully this helps talk at you later
I did some homework and found that the nissan maxima with a v6 from 86-92 has a 90amp alternator and the only modification is to change the pulley and hook up the nissan plug-in. I put one on my 86 gl wagon and it works great.
the alternater cost me 15.00 at the junk yard and 20.00 for pulley.
hope this helps
awesome job on the video . that realy kicks
Hi guys my name is steve and I have an 86 gl wagon. Its my second subie and I
love it. My first one was a 84 gl wagon and it was a good car to until I killed it.
Oh well my 86 is better,I built a front and rear bumper for and a roof rack for it
My next project is to build a tire rack on the back bumper.
lift kit parts
in Off Road
Posted
cool
